Hey Guys,
While driving my r33 gtst today i heard a noise under the car pulled over and there was a sensor that had fallen from somewhere scraping under the car. So i got the car home straight away and put it up on the ramps assuming it was my o2 sensor however its after the cat in the middle of the car on the passengers side and the wire runs up through a gromet to a fitting underneith the passenger seat. However after a closer look i realised that there is another sensor further up the exhaust which is obviously the o2 sensor. Does the r33 run a temperature sensor in the exhaust? I cant figure out where it has come from or what it is.
The sensor is damaged so i need to know where it is supposed to go and what it is so i can replace and fix the problem.
Thankyou for your help,
Regards
Dan
https://www.sau.com.au/forums/topic/102654-exhaust-sensor-fell-out-s/
From what you have described it is the exhaust temp sensor. I'm not familar with the temp senor arrangement in the R33s but the R32s have a sensor/switch which screws into the CAT. Unlike the R32s the R33s exh temp sensor is monitored by the ECU (signal wire is Pin 57 and earth for the sensor is Pin 30).
If you have an aftermarket CAT its possible no provision exists for the sensor in which case it was left loose after installation of the CAT.
Can you take a photo?
Hope this helps
Cheers
Edited by BH_SLO32
Its a CAT Temp sensor.
So.......
Dont worry about it. Its just used for a dash light, serves no other purpose.
Its perfectly safe to tuck it up under the body, or remove it all together if you wish, your choice. Wont hurt the car by not having it
I havent used my since day one of owning the car.
Not has anyone else thats changed thier CAT as far as i know as most non-factory CAT's dont have a hole in them anyhow
Hope this helps
Cheers
what do you need to do to stop the exhaust temp light from flashing on your dash all the time as i have a faulty sensor
O ok well that would be the case then you see i have a trust turbo back exhaust so its all aftermarket. The cat included there is no provision for it. It must have been sitting on that cat itself which was providing enough heat for the warning light to be off for the majority of time while driving. I was concerned that the heat sensor would impact the engine by if the sensor was saying that the exhaust gases were to hot that it would run more fuel to cool down the temps. Are you certain that this isnt a case and it serves little more then a potential light show on my dash?
As i said, im am 100% certain. I havent run it on my car ever. Its just tucked in there.
Its only an "over temp" warning for the CAT. Ie its getting to hot, which for anything other than a stock car... is probably gonna happen.
Just tuck it back under there :)
hefer81 - If your light is faulty - you'll probably just need to rip out the globe :) Although i havent heard of one every playing up.
Or maybe see under the car where/what your sensor is upto.
I have taking my sensor out completely as the ligth was staying on as it was damanged from draggin on the road. This made the light on the dash turn off so im just going to leave it out and put the gromit back in. This wont be a problem will it?
No problem doing this. If by removing the sensor the light has turned off, the problem has been solved.
sweet thanks mate all finished ive plugged the hole back up lol i used a despent .22 long rifle shell to fill the hole in the grommit where the lead went through into the car to block it off so water doesnt get in there :(
I have had this exact same thing happen on my GTR it is good to hear that it is not causing any harm, my warning light also flashes constantly, i will have a set of nismo gauges soon so when that comes i guess i will just pull the globe. My exhaust is still stock does anyone have any suggestions on how to block the hole?
Sorry for the tread hijack
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
