A few of those have been around for a coupleof years now
I think it was ACA that did a feature on some guy with a black VU Commodore SS ute that had a huge "THIS CAR IS A LEMON" sticker up the side of the car
At least the guy's got new car warranty behind him, I know what it's like to be stuck with an old lemon that needed a fix every week or two
lol I'd love to see a skyline driver try that shit about their car... "sent a letter to NISSAN, they offered me a pat on the back and told me to fcuk off and die". At least he got a free service, If it was that faulty I'd be selling it as soon as the warranty period was over.
The XR6Turbo is a awsome car and great value for money.
Very few have problems, but the ones that do are generally fixed under the new car warranty. I know the guy who owns that car and his problems are mainly due to his pathetic dealer. This seems to be the biggest problem with Ford is their woeful dealer service network. They will try to weasel their way out of warranty work, but if you are persistant, the problems are fixed eventually.
My XR6T is my first Ford, but I have just ordered a FPV typhoon as a replacement, so I guess you could say I am happy overall. While I had some issues with my car, I did not take the dealers BS and all the problems were sorted out.
welcome to last year!
i was going to say the same thing, but its a different car this time...both were XR6T's though...
that being said, thats 2 out of a shit load that have been sold...every manufacturer has lemons, thats what happens in mass production.
being a big ford fan i was on a ford forum for some time before coming here and buying a skyline, and ive heard all about fords terrible excuse for customer service.
they got the cars right with the BA series, but customer service went completely down the drain
yeh i rekon xr6t are good, the problem is the production line, usually the faulty ones are the ones that they rush on a friday orvo to fininsh building, or they leave them on a friday arvo half done for someone else to fininsh on a monday, i have found thats the common problem.
Oh theres definately lots of lemons around. Back in Feburary 2005 Motor tested a Typhoon and the first day they had it the clutch f**ked up hardcore and couldnt be driven so Ford rushed them out another typhoon and after 8 laps around winton the Clutch in that f**ked up aswell and couldnt be driven at all.
hahahhaha ford Accused them of flat shifting (Keeping the gas on while sihfting gears), while they said they didnt do that at all they raised the issue of why this wouldnt of then been tested anyhow knowing that certain drivers would do this.
Seen a Territory on the northern beaches with a big similar sticker saying what a piece of shit lemon it was raving on for ages and ages.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
