howdy, i recently installed a turbosmart eboost, but i cant seem to boost over 7psi, the guage runs three adjustable set points, which i have set at 1-7psi 2-10psi 3-13psi, i run the eboost soildnoid straight of the trubos wastegate, so there shouldnt been any factory boost cut out stoping it should there, any suggestions.
https://www.sau.com.au/forums/topic/102802-eboost/
Make sure you have the solenoid hooked up correctly. Port 3 of the solenoid is manifold pressure, port 2 is actuator reference and port3 is vent. There are three setting boost setting - SP1, gate pressure and sensitivity. Set SP1 to you desired boost level then adjust the gate pressure until it just starts to overshoot your desired boost level and set the sensitivity so that boost dosn't drop off higer in the rev range.
That said I have had alot of trouble setting these boost controllers and dont really have much respect for them.
https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888152
cheers, il have another go at it, yer its a bit bloody tecnical for first timers like me self, gate pressure, sensitivity, heaps of stuff to mess with, but il keep at it, even when i reset it all and set sp1 at 10psi, still couldnt get over 7psi, checked the hook p three times now all looks right but will check once more just in case.
https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888335
The values you put in are a little miss leading as they are not in boost pressure. It may be Duty Cycle but I'm not really sure. So if you set SP1 to 10 it wont necessaryily give you 10psi. Try setting it 20 then 30 etc etc until you get the desired boost level and then you will proably find that you will have to increase the sensitivity to stop it bleeding off in the top end.
Does anybody know if there is any kind of feedback control as in closed loop operation PI or PID loops, or is dumb as shit? Has anybody check the duty cycle on the solenoid to determine if it changes up and down or only up or does it change at all from the set DC.
https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888352
ok just went for a spin out on the old knob high way messing around with set point one i tryed seting it at 20 with a gate pressure of 20, and then 30 with a gate pressure 30, done a few 1st and 2nd gear rolling take offs, evry time i booted it, it would still only get up to around 7.2 was the highest, but every time i changed gears, and flanted it again i would get a sudden boost spike to around 9 some times 10 but would drop straight away to 7 or lower. had the sensitvity high as well.
dam thing would all ways crunch a little into 4th and 5th and back into 4th, at revs its ok around town driving or cruzzen.
https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888502
Check the over boost isn't set at like 8psi.
https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888507
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
