howdy, i recently installed a turbosmart eboost, but i cant seem to boost over 7psi, the guage runs three adjustable set points, which i have set at 1-7psi 2-10psi 3-13psi, i run the eboost soildnoid straight of the trubos wastegate, so there shouldnt been any factory boost cut out stoping it should there, any suggestions.
https://www.sau.com.au/forums/topic/102802-eboost/
Make sure you have the solenoid hooked up correctly. Port 3 of the solenoid is manifold pressure, port 2 is actuator reference and port3 is vent. There are three setting boost setting - SP1, gate pressure and sensitivity. Set SP1 to you desired boost level then adjust the gate pressure until it just starts to overshoot your desired boost level and set the sensitivity so that boost dosn't drop off higer in the rev range.
That said I have had alot of trouble setting these boost controllers and dont really have much respect for them.
https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888152
cheers, il have another go at it, yer its a bit bloody tecnical for first timers like me self, gate pressure, sensitivity, heaps of stuff to mess with, but il keep at it, even when i reset it all and set sp1 at 10psi, still couldnt get over 7psi, checked the hook p three times now all looks right but will check once more just in case.
https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888335
The values you put in are a little miss leading as they are not in boost pressure. It may be Duty Cycle but I'm not really sure. So if you set SP1 to 10 it wont necessaryily give you 10psi. Try setting it 20 then 30 etc etc until you get the desired boost level and then you will proably find that you will have to increase the sensitivity to stop it bleeding off in the top end.
Does anybody know if there is any kind of feedback control as in closed loop operation PI or PID loops, or is dumb as shit? Has anybody check the duty cycle on the solenoid to determine if it changes up and down or only up or does it change at all from the set DC.
https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888352
ok just went for a spin out on the old knob high way messing around with set point one i tryed seting it at 20 with a gate pressure of 20, and then 30 with a gate pressure 30, done a few 1st and 2nd gear rolling take offs, evry time i booted it, it would still only get up to around 7.2 was the highest, but every time i changed gears, and flanted it again i would get a sudden boost spike to around 9 some times 10 but would drop straight away to 7 or lower. had the sensitvity high as well.
dam thing would all ways crunch a little into 4th and 5th and back into 4th, at revs its ok around town driving or cruzzen.
https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888502
Check the over boost isn't set at like 8psi.
https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888507
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
