Item: td06h 20g
Item Condition:good
Reason for Selling:need cash
Price and Payment Conditions:650 plus postage
Extra Info: i can arrange some pictures, please email [email protected] and ill send you off some. This turbo made ruffly 340 rear wheel horse ona rb20. T3 connection, so can use the standard rb20 manifold. Polished front housing, oil cooled only.
Contact Details: pm or email [email protected]
Cheers justin
https://www.sau.com.au/forums/topic/102889-td06h-20g/
it is actually internally gated..theres a few guys interested... email [email protected] if ur still interested and ill send you off some pictures tonite...
Cheers mate justin
pics up please.. very very interested.. is it an external wastegate type??... cheers
https://www.sau.com.au/forums/topic/102889-td06h-20g/#findComment-1890405
Hi interested in the turbo and live in perth. Does the turbo have any shaft play? I'm guessing it will bolt onto an rb25? Can pay cash if you are interested sms me your moile number to 0417990398
https://www.sau.com.au/forums/topic/102889-td06h-20g/#findComment-1893639
Hey mate,,, i now have pictures... turbo is in good condition... sorry ive lost my mobile, pain in the arse... if you like email [email protected] if your still interested and ill give you a buzz tommorrow at work.
Cheers mate justin
Anyone else after pictures email [email protected]
Cheer justin
https://www.sau.com.au/forums/topic/102889-td06h-20g/#findComment-1895101
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
