A few items I need to get rid of as they have been sitting in my garage for over 1 year.
Items
1 x Black/Red and plain Red recaro replicas.
Made with proper steel frame and injection moulded foam. I use a similar pair in my R33 with harnesses at tracks with team wang.
$600 for either pair
Melbourne
Item Condition:
All new
Reason for Selling:
Taking up 2 much room in my garage
Price and Payment Conditions:
Prices in thread.
Extra Info:
Contact Details:
email me at [email protected]
https://www.sau.com.au/forums/topic/102914-a-few-bits-and-pieces/
Hey mate, do they have rails or do they fit straight onto r33 rails?? Do they have the proper recliner set up for a coupe?? What adjustments dot hey have? height. lumber etc. Are they comfortable? How do they compare to a standard GTST seat?
This is the pair I have in my R33. They come with generic rails.
I ended up getting a pair of bride rails suited for an R33 from a jap importer and then modifying the bolt locations on them to suit the seat as the floorpan under the seat area on the skyline is at all different levels so its a bitch to modify other rails to suit. Another problem is that the stock rails have the seat belt buckle as apart of the rails also. The bride rails went straight in with new belt buckle etc.
They recline so you can get into the back seat. Thats the only adjustments they have and are very comfortable and hold you in nicely.
drift monkys
If i sell you just the drivers side, then I will be stuck with a passenger side that no one usually is looking to buy.
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
