I currently have a 1990 hillux surf turbo diesel which I imported about 6 months ago to which I have done a few mods which is my daily driver but now want to sell and get either a Soarer V8 or Celsior V8 coz driving a big diesel 4x4 everyday is a pain in the ass, especially is city traffic. The R33 spents most of its time in the garage when not being driven on the track.
This saves me alot of $$ on petrol and hassels from cops as I work in the city about 40km from home.
There are alot of soarers for sale but only a few celsior, which cant be imported now either under the 15 year old rule but they both have the same 4.0 engine.
Who's owned one or had good/bad experiences with them?
Yes I have already driven both before but am stuck between the 2.
Yes I need people on the internets views before I buy one :):)
https://www.sau.com.au/forums/topic/103061-soarer-or-celsior/
  • Replies 41
type C F has massage rear seats, standard leather, air purifier the whole lot.
you're not really pimpin unless you in a C F.
i was lookin at getting into a celsior not long ago, there is a whole lot to look out for with these cars. you can quite easily end up spending a GTR-load of money getting them up to scratch, not a cheap car to run.
check out some of the info from the toymods forum -
http://forums.toymods.org.au/index.php?t=m...94a6ebc98d80888
helped me decide i didn't need one :D
I'd get a soarer Denham... unless you want a 4 door. Just because there so many of them around these days, parts would be a bit easier to get.
Most of the JZA80 Supra suspension components and the like bolts straight into the Soarers, which might mean its cheaper prospect - if there is anything like that needs replacing.
If you want a four door, get a Celsior. If you want a two door, get the Snoarer.
They're not exactly similar cars.
A friend of mine had a Celsior for a while. The V8 sounded nice with its catback, and was smooth. It was a full luxo inside, with a rear seat you could use. A pretty nice car - shame you weren't looking for one a month or so ago.
Yep looks like I am going with the celsior.
Checking out my mates I might be swapping with tomorrow again.
Heres mine. black one is for sale atm - put it up in FS section, but for some reason i think someone deleted it.
There are many things to look out for on celsiors. air suspension is not really a problem...its more the shockers and ball joints.
BTW - CF is more luxury but if you have a C model, you can easily add rear massagers - they are a seperate unit that is added in the back of the rear seat and you can get em from japan easily.
How much u selling the black one for?
I think i will just put some 19's or 20's on the 1 i get and not the bodykit so I wont have to worry about going uo driveway/carparks and hitting the kit I have to with the R33.
How are they as a daily driver? Are they good on fuel?
get an aftermarket suspension height controller and your driveway problem is solved :(
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
