I posted a thread the other day about my exhaust temperature sensor (http://www.skylinesaustralia.com/forums/index.php?showtopic=103482)
Since i re-screwed in the sensor it ran fine for a day but now the warning light is flashing again, its not the engine light the symbol looks like a cat converter with steam coming of it, i assume its a temperature warning light. Since this light is still coming on and off while im driving does that mean that i have to replace the sensor cause its damaged? (since it got filed dragging on the road) if so how hard is it to replace (can i do it myself) and is it an expensive item to buy? Is damage going to be done to the car if i keep driving it with the warning?
The second problem is from what ive read is common but i just need clarification. When im driving my car a bit harder (above 5500rpm) it stuters a bit under boost and the revs are not smooth to the redline. From what i can remember it is most likly the spark plug and or the coil packs that have given up and can no longer provide a good enough spark under high boost pressures. Is this correct and if so what sort of price am i looking at to get new plugs and or coil packs (splitfires etc) and how easy are they to install can they be done by most people? or are they more a job for an experianced auto electrician?
Any help regarding these question will be appreciated, thanks in advance.
https://www.sau.com.au/forums/topic/103704-gtr-problems-and-advice/
Just did a bit of searching and found out that the exhaust sensor is not needed and wont cause a problem so i will remove it all together and plug the whole.
I would still like conformation on the second question regarding inconsitant revs, is it the coil pack and or spark plugs?
$25 for a set of plugs will answer that question
I had that Exhaust Temp Sensor light on in my GTR for a while, not long after I had new turbos fitted, the car started running like a dog and the Cat was steaming! (Cat and dog reference pure coincidence! :P )
So initially I thought the Cat internals had melted...and well...had it removed.
Car still ran like a dog and would only run on the smallest of throttle openings.
To cut a long story short, I stumbled across the problem when removing the Plastic cover which bridges the rocker covers on the RB26, Not long after having new turbos fitted I painted the rocker covers, and had removed this panel, when putting it back on I did not plug the ignitor back in properly (Mounted on the panel) hence the plug came loose and car ran like shit.
Put the plug back in and No problems to this day!........
... if so what sort of price am i looking at to get new plugs and or coil packs (splitfires etc) and how easy are they to install can they be done by most people? or are they more a job for an experianced auto electrician?
As mentioned, plugs around $25, Splitfire coilpacks around $600 depending upon how you source them.
Plugs are super easy, coilpacks come off to access the plugs and from memory they are plug and play also.
DIY approved! :D
You're welcome! DIY always starts with oil changes and plug changes and you try harder stuff from there. :) I'm a DIYer too.
There is a well illustrated guide on www.niztek.com (or .au?). I found removing the ignitor plug to be the hardest, but my car is a lot older :(
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
