Hunter Valley Lunch Run, 29/03 (at last a date!)
  • Replies 244
Ok, so what are the thoughts? where are we leaving from and what time etc???
Everyone knows that my suggestion is the putty road... so come on... lets get something happening!
Details will be posted by the end of the week. I will be sorting out the Meeting Points and Route most probably tonight.
I still have a few options on destination but I'll make the final call by the end of the week :D
UPDATE!!!!!
Meeting point will be THORNLEIGH MCDONALDS @ 8:30am for a 9:00am sharp departure
We will be hading up the old pacific highway to West Gosford McDonalds to meet a few people from the coast. From there we will endeavour to leave around 10:45 ~ 11 to drive up the F3 to the hunter. I have had a few very interesting suggestions on destination today so am still undecided on the destination.
Hope this helps you guys out in the mean time :)
Stay tuned :(
jt im guessing the meet up (i suggested to toshi) that TWS people can met up at the cumbo BK or cumbo macca's whichever u prefer... most prob the BK as its closer to the m4...
then meet up gay... i mean TNS poeple at thornleigh macca's then cruise up together from there....
also must agree toshi 9:30 departure from thrnleigh is a lil late.. not taking into account donnie might be coming so you will leave more like 10:30 :D
probably 8:30 meet (even earlier if possible) and SHARP departure at 9:00... if ur late u can meet up at west gosford macca's or try and catch up...
guys, the official meeting point is Thornleigh Macca's.
If groups of guys want to meet elsewhere, then please feel free to do so however you will need to be @ Thornleigh McDonalds by 8:30 so that we can leave @ 9:00am SHARP
I have considered meeting at homebush and cumberland macca's but have come to the conclusion that in order to get to the hunter at any decent time, we'de have to be meeting @ homebush at like 7am.
p.s. if u wish to discuss alternate meeting points amongst yourselves I have no problem with that. All that I ask is you do not do it in this thread as it may cause some confusion for people who are reading through.
Jimbo: fun can be had on the old pacific highway :D
THORNLEIGH MCDONALDS @ 8:30am for a 9:00am SHARP departure
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
