Hi guys.
How is everyone? Better than me, for sure! Recently I took my car to a shopping centre, did my shopping and returned to my car only to find the front bar had been damaged! I believe it is repairable but would like to purchase a front bar with or without foggies as it would be easier just to respray one.
If possible I would prefer the front bar to be in Silver, include the foggies and be located in Sydney for pick up but all of these are not expected, I am quite flexible in this regard.
Would anyone know a good smash repairer in Sydney with reasonable prices for repairs and resprays as I am considering doing both. I am a bit worried about some suspected rust in my boot will get pics up as soon as possible as I am not sure on the what it is and/or how worried I should be!
If anyone has any information, please let me know!
Regards
Drift King
https://www.sau.com.au/forums/topic/103809-help-needed/
Hey guys,
I just got my front bumper resprayed and repaired last week.
Initially all I wanted was the lower bit fixed up because I cracked it going over a bump. But when I got quoted $150, I thought what the heck ant do a full respray for another $150, so $300 all up.
They did a great job, the front bar even felt more solid
I used xtreme-bodykits at warwick farm
They take the bumper off and you drive drive around without it for three days before you go back and put back on.
https://www.sau.com.au/forums/topic/103809-help-needed/#findComment-1910052
Speak to Frank @ 'Caldwells' in Condell Park
Tell him I sent ya.. he's very reasonable and also very good.. did the bodykit on my car and re-sprayed my wing to match KENNEDY's car, where it now lives :ban:
BTW.. I am selling my M-spec bar without the lights, if interested please PM.
https://www.sau.com.au/forums/topic/103809-help-needed/#findComment-1910682
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
