I have a neo RB25 det engine out of an r34 with a manual gearbox attached. Was wondering if anyone had any advice on how to drop it into a VL commodore. I know i should be putting it in an s13 or r32 etc but i already have an r33 and me and a friend want a sleeper. Anyone know which tail shaft i can use and if the rb25 engine mounts will bold straight onto the VL cross member? Any onfo would be much appreciated.
Nate.
https://www.sau.com.au/forums/topic/103986-neo-vl/
Nate.
rb30 vl engine mounts (shimed on the right hand side for break booster clearance
vn-vp auto or manuel (cant rember) gearbox crossmember (something like that)
std vl tail shaft using the yolk out of the neo,with a diffrent uni-joint to mount to the vl shaft
will need to up grade the fuel pump, need to modify the p/steering pump mounting bracket, a/c std vl bracket with washers under for spacers
throttle cable i use the std but the cable is much tighter and is wraped diffrentley and looks crap (i thnk the neo has a electric butterfly also but no idea what its for.
then the obvious computer and loom needs to be modifyed to work with the vl bodey loom for starter motor and alternator etc
(my rb25de) i changed the lower radator hose intake pape (to the motor where the thurmo stat is mounted) to the vl one as i was reusing the lower vl radator hose may also need to do that if u like.
i also used a cut lower radator hose for my top hose and the 2.5's are diffrent but u might be able to do something else
all in all there isnt much that needs to be done
https://www.sau.com.au/forums/topic/103986-neo-vl/#findComment-1912595
Nathan,
There is a guy in my area with the exact same setup - only he is near finished :D
If you want I can get you some contact details :D
For starters look at this:
http://www.tuned4street.com/index.php?showtopic=4116
https://www.sau.com.au/forums/topic/103986-neo-vl/#findComment-1912724
This VL is stockers as externally. Put it this way, when i'm in my skyline, i believe i can beat any commonwhore on the roads, which is true in most instances. The car i'm putting the rb25 DET in is a plain white VL commo. That is a sleeper, especially after i'm done with it.
https://www.sau.com.au/forums/topic/103986-neo-vl/#findComment-1929236
mate just make sure u have mudflaps, dashmats, 15' intercepters with hub caps, nudge bar, tow ball, extra view rear vision mirrors(the ones u use with a caravan) etc.... and it will be sweet.
oh yeh i think the standard vl crossmember will bolt up to the gearbox(if its the same as the r33 gbox)
it'll be a tight fit but gl.
Edited by joe2548
https://www.sau.com.au/forums/topic/103986-neo-vl/#findComment-1937141
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
