Hi all, hoping some of you guys can answer a few questions for me.
Firstly, has anyone found a reputable source for bodykits for 4 door R32 GTS-T's? Specifically Vertex style kits?
Secondly, has anyone tryed to fit R33 GTR factory wheels to their 4 door? I know the wheels physically fit, but I would like to confirm how much work in terms of guard flaring/rolling would be realistically required to accomodate these wheels on the 4 door - assuming the car is lowered 1.5-2 inches all around.
Thirdly, R32 GTR rear seats in a 4 door - possible or impossible?
Cheers,
Nick :rofl:
https://www.sau.com.au/forums/topic/103997-calling-4-door-r32-owners/
"Secondly, has anyone tryed to fit R33 GTR factory wheels to their 4 door? I know the wheels physically fit, but I would like to confirm how much work in terms of guard flaring/rolling would be realistically required to accomodate these wheels on the 4 door - assuming the car is lowered 1.5-2 inches all around."
Ive got s15 rims on my car and its fairly low no probs with scrub biggest tyres I run are 225's
No worries Blitzeh :P
Try G-Force in syd, Avi Prasad is the bloke's name who runs it I think. He's on this forum, and I think he was looking at becoming a sponsor, dunno how he went with it. His website is http://www.jap.com.au in any case. The kits fit pretty well from the ones I've seen, and his prices are pretty damn good. The website has the coupe kit listed only, but I remember him mentioning the 4 door kit was in development last year, so it might be ready now.
Roll and flare of guards required in the front, might be able to get away with a roll only in the back. 4 Doors look tougher with flares all around anyways.
Possible, I've seen a few cars with em done... however the mounting positions don't line up exactly the same, some customising is required, and shutting the door is a little harder.
All possible... A group called Panteraftermarket (www.pantheraftermarket.com) do Vertex bodykits for 4 doors. Or Adrenalin Autosports as well, located in Sydney and Queensland respectively.
R33 GTR wheels will fit. Depending on your ride height, you might have to roll the guards, namely the rears. I had too.
And I also have an R32 GTR seat in my car... fit like a glove.
p.s Are you stalking me?? haha :rofl:
Here's Panther...
Panther Aftermarket
HEAD OFFICE
Unit 8 Industrial units
Crescent Head Road
KEMPSEY
PH: 02)6562-2556
FAX: 02)6562-2556
EMAIL: [email protected]
Bank Details for Direct Deposit
ACC Name: Panther Aftermarket
BSB: 032-580
ACC:146589
I'll have to get back to you with Adrenalin.
what are the offsets of R33 gtr rims?
ive got 18x9 +30 on the back of mine and they fit without any modifications. and my car is quite low... can just see the top of the tyre under the guard.
are the leather gts-t seats different to other gts-t and gtr seats? cos i tried puttin my mates leather seats in my car (cos mine where out and people needed to be driven places) and the backrest was too short
how do u roll the rears when theres no real guard to roll? theres like 2cm of panel that goers around the wheel
I had it done from group in richmond, just normal guard rolling machine. $50 a corner. It's not all the way round, they just rolled where the tyre would sit and a small surrounding area.
Heres an update for you all.
I have fitted R33 GTR wheels without a problem, mind you the car isnt lowered as yet, however the wheels have advan 225's which are undersized for these rims on a GTR, but work well for this application.
GTST: I had R32 GTR wheels on the car previously and noticed a bit of rub on turn, but havent as yet with the 33 GTR wheels - odd.
For some reason im really keen on the 4 door now and its my new project - so the hunt for parts continues!
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
