guys, you are going to laugh at this :P
Anyway, I was replacing my bulb which blew and the bulb snapped off and fell back into the low beam area of my front lamp.
Have a look at the picture. See the thing in red? that's the old bulb.. It's fallen into the enclosure.
Seriously,Does anyone know how to take that broken bulb out of that area?
ta!
Piece of Blu-tac on the end of an opened-out (wire) coathanger fed through the globe fitting hole.
You are a genius!! thank you !! I will try tonight when i get home from work. I tried using a straw but it can't bend..
thought abt blue tack but blue tack only works IF u were to hold 2 pieces together-then it will stick . Else it does not... anymore ideas??
Stop, you're embarrassing me :)
If Blu-tac doesn't work, something like chewing gum, or maybe dollop of fresh (un-cured) silastic on the wire.
YEAH!!!1YES!!! THe Age Old Yankee "power tool" - Chewing Gum!!! Damn!! It Slipped my mind!!WOO HOO!!!!!
(People reading this must think i am going outta my mind ..It is actually considering i can;t sleep over it. It is my bro's car and i am taking care of her while he is abroad working).
man i almost dropped the gum in the damn low beam chamber. Gave up and decided to shuff the farking thing in this little 'line' section in the chamber...
damn
guys, anyway of opening up the damn light chamber safely without damaging it??
damn
did you not read my post up above?
hey there
it's weird... your post wasn't showing before... yeah that was what i was thinking and i did post up-"how did you open up/remove the headlight unit?".
ta! :D
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
    • Going by the intake & injectors I'd be guessing it's a DE, check the head casting number, should be 5L8 on a DET, 5L7 I think is the DE number.
    • For future reference, if you need to use Deutsch connectors but don't have the proper crimper for the round style pins, you can get regular style crimp pins too
    • No. The castings are all the same. As you have the inlet off, simply measure the diameter of the inlet ports and compare with the freely available on the net sizes of turbo and NA. The NA ones are small.
