the wrong cd's were mistakenly loaded onto a plane from kuwait and due to the religious holiday over there at the moment there will be a delay on the correct cd's
due to the banks raising their fees so much he only ended up getting $2 from each of us and couldnt afford to send them
Edited by mcnamg
  • Replies 306
Posted Images
the complaince workshop is still waiting for dotars to come and complete an inspection of the CD's before they can be complied
funky had a knock on his door from two big maori guys from jpnz wanting to know where he got his manuals from and nobody has seen him since
Edited by mcnamg
some bad taste, about the wrong body being sent from kuwait isnt very nice, and the tassy miners, they have greaving families and u guys are making jokes out of em both :P
i think he is just too damn busy and totally forgot they were even meant to be sent :devil:
Here they are so far - keep them rolling in!
..and I don't think any have been in bad taste yet, ie it is very Australian to make jokes about bad things that are happening, it's part of the reason I think we have the best sense of humour in the world (when I was living in the USA, I had no problem talking sex, politics, or religion with my local friends. But humour, particularly sarcasm, was an absolute non event...)
Ian -
1) "The guy posting them went home when the commonwealth games finished, and took them with him"
2) "global warming melted the stamps of the envelopes, so they have been returned to the sender, who accidentally put the wrong return address."
3) "an Australian Idol star has stolen them, as they were desperate for more CD's to record demos on"
4) "A miner in Tasmania has them, and he is having trouble getting to a post office"
Ska -
5) A dingo stole them?
munchdesign -
6) John Howard has ordered a parliamentary enquiry into their disappearance.
Tangles -
7) Envelopes were used as toilet paper in a time of crisis.
8) Cds were used by the kiddie & dog in a frisbee free-for-all game.
GoldZilla -
9) The CDs are now doing triple-duties as either a plate for meals, a mirror for applying make-up/brushing teeth, etc., or as a mirror once again for use to rack-up the current possessor's drug of choice for the day - all depending on the requirements of that particular time of day.
mcnamq -
10) the wrong cd's were mistakenly loaded onto a plane from kuwait and due to the religious holiday over there at the moment there will be a delay on the correct cd's
11) due to the banks raising their fees so much he only ended up getting $2 from each of us and couldnt afford to send them
12) the complaince workshop is still waiting for dotars to come and complete an inspection of the CD's before they can be complied
13) funky had a knock on his door from two big maori guys from jpnz wanting to know where he got his manuals from and nobody has seen him since
CruiseLiner -
14) i think he is just too damn busy and totally forgot they were even meant to be sent
yeah but with an average post count of about 93 posts per day, i dont think he is gonna just stop posting on the forums because of this debacle... maybe im wrong but im guessing he's not back at work yet
if hes like me and he has this site as his homepage then if someone else turned his computer on and used the internet then that would count as a login I believe. so if someone lives with him parents or partner or roomate or whatever they may have used his pc
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
