  • Replies 306
Posted Images
lol sorry guys I'm runnin on a backlog of PM's since the forums were upgraded with people wanting all sorts of stuff fixed.
I'll reply to PM's from you guys and post up an updated payment recieved list asap.
I'll chuck both split and single manuals on the CD. Best idea evar!
hey funky whats the hold up... any idea when we shall recieve it or have u skipped the country with your small fortune :D
sorry for pissfarting around guys... just haven't had the time to finish em off. I'll be spending some time tomorrow morning finishing off the reauthoring of the PDF's (stupid japanese seller password protected all of em) and burning em onto CDs so I can send em off on Monday, or if I do em quick enough maybe even before the post office closes on Saturday.
Ian or Alex, if you want I can meet up with you somewhere around the Glen Waverley area and give you the CD's for the melbourne based guys so you can hand em out at the next meet. Otherwise I'll just post it out.
I suspect they won't be happy waiting to the next meet, so mail them out! :(
(I assume you had no trouble getting rid of the password? If not, send me a pm).
Ian
yeah I downloaded some password cracker thingamajiggy that got rid of it. The main delay was to get the full version of Acrobat 7.0 so I could reauthor the PDF's. All done now, unfortunately have to wait till Monday to mail em out.
Yeah, um, like... monday came....and so did tuesday...and wednesday, thursday and friday too......any news?
At this stage, id rather just come pick it up from your place. GW is on the way to uni for me every day so that would be easy enough. Otherwise, if it is actually sent this week, ill wait.
PM me your number or something. Thanks
They were sent middle of last week (using regular post) so it should arrive soon.
If there's anything specific in the meantime that you guys need urgently let me know and I'll post a screengrab.
hey funky i need abit of info or a screen grab if ya can, of the fuel pump relay (mounted on drivers side under kick panel) and wiring to the pump in the tank, i also think it runs to the engine ecu as well. its a black wire with a yellow stripe (its the main power to the fuel pump). let me know if u find any diagrams of relevance :thumbsup:
cheers
Edited by CruiseLiner
I normally get things in a day, but nothing has arrived. Can you check that you sent it to the address I PM'd you?
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
