you mean access to remove them from the boot? you need to remove the carpet panels then they just unbolt from the inside.
ok cheers. and the lil side indicators. just pop them off with a screw driver?
  • Replies 156
Posted Images
Just having a bit of trouble with the rears. I have taken all those little annoying screws out of the carpet and bent it back so it is out of the way. I can see all of the bolts I need to remove, but there is no damn space to get a spanner in! How the hell do you do it?
Yep ill have to do that. Back to the idicators now, I have taken them off and now all I have is a big piece of white plastic and the orange cover. How the hell do I remove them? I cannot get the orange piece on its own!
I realise that doesnt make a hell of alot of sense. I'll take some pics later on :D
you're talking about the side indicators or the front ones? the side ones just come out as one unit, i didn't think you could separate them. i'll have a look at my old orange ones tonight and see if i can give you some advice. i don't need them anymore so i can afford to break them
ok cheers :D
Did front an side indicators today
Think I went a bit overboard... I didnt want them black to start with. Meh, they are really dark. I'll take some piccies tommorow mornin when I get home froom work, overall very happy with it though.
I also have another surprise to take some piccies of tommoro :D You will Love it, garunteed
love the front indicators ... they came up looking great.
I'm pretty sure l've found out a cheaper alternative for clear side indicators as opposed to importing them, am going to double check this week they fit, then post up details. They're only about $50 inc postage. Just the fronts l'm not sure on yet on what alternative's there are about.
lol @ the space saver ... car looks like something ronald would give u in a happy meal being those colours!! :lol:
Edited by [ STAGEN ]
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
