  • Replies 158
Posted Images
I can have a go, sure. I'm not as expert as my nitro-racing friends, but it shouldn't be too hard to tune it up. An infra-red temperature gun comes in handy though!
I'm guessing that you're running pretty smokey even on WOT?
I have been racing on road R/c cars for about 5 years and am a member of a world class track located in Moorebank just off the M5. Membership costs $80 a year and with that you can get to attend race meets alot cheaper and you get a set of keys to the track! So when there is no club racing on you can go and practice or have a drift meet with friends etc whenever you want. So if you want to have a rc get together at a proper track this is the place to do it.
I have some pics of the track and my rc car at a race i attended last year.
Come out to a race and get a membership form and pay. Races are the 1st and 3rd sundays of each month. The next race meet will be pretty quiet because there is a big race in brisbane next week so next week would probably be good to come join up and maybe get your car on the track. There is ussually a website with all the info but for some reason its down at the moment. Its in Helles reserve at Moorebank, On the intersection of the M5 and Moorebank ave.
It's a solid hour drive for me, but if eveyone is serious about proper drifting on a track, i'll happily pay the money.
Members have keys, but are they allowed to invite their friends in?
Thanks for the info, Chris!
wow.. just looked at the pics... it's not a particularly tight track, is it? I'm not sure how it'd go for drifting, but i'd definately give it a try!
Last time I got a drift session on a track was during a "dinner break" of a club meet when they weren't using the track.
I don't think anyone has planned to go to the track, but i'm going to suggest: Sunday the 19th at Curl Curl netball courts. (Northern Beaches)
I will go down and check it out to make sure there isn't a ton of netball games on, but when there is, there is usually a court free. It's easy to access and quite smooth for asphalt.
We'll just meet up and muck around without any track (unless someone brings some), and if it is successful, i'll look to organise something more proper for the next meet! (which could be somewhere else too!)
Please post IN or OUT for midday Sunday 19th meet at the above location!
Edited by RANDY
sorry RANDY, ive got parts arriving for my car this week so i'll probably be putting it all back together on the weekend.
sorry mate, i might go check that moorbank place out though.. im from bankstown so its not far for me.
Security: the controller and receiver use a frequency-modulated cystal to communicate. If two people have the same, or very similar frequency, you'll both be controlling two cars each. Interesting, good for a laugh, but then you just get the shyts.
Steve and Paul IN! =-D
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
