  • Replies 170
Are there spaces left? What's the go if two people want to share one car? Does Mr. McGill frown upon this? I take it you also don't have any problem with non-'lines carving up the concrete? :P
EDIT: Damn, I see I'm now on the second page, and it seems to be full. Anyway, if I'm wrong, please let me know!
Tex
hey all i am pretty new to these forums and to import ownership in general.
How would i go about getting in to just watch and maybe meet a few of you guys in person?
I am interested in getting together with other people who own skylines and this seems like a good opportunity.
Originally posted by Duncan
The buick dorifts?
Sure, don't see why it wouldn't. It's RWD, has a stack of power, and a nice tight limmie - why not? ;) It'd be a real challenge to keep on track though, when 2 tonnes breaks traction, it tends to want to go its own way. I've tested it. :)
Originally posted by red900ss
4 tonnes of Detroit steel floating on marshmallow suspension and cross plys...you don't expect it to handle do you?? :P
Hehe Dino, it's a more conservative 2 tonnes (as above), and it runs radials now - but still, NO. :D:)
As much as I'd love to try the Riv out on the 'pan, it may not be avialable at that time - hopefully it'll be in getting treated to a full respray, and other resto work. I was intending to bring Daddy's BMW.
Anyway, see you all there as a spectator, I imagine. :)
Tex
Thanx for the pm pete, havn't been online for while. The Teins are up to the challenge, and the tyres are bald with the belts comin thru big time (your specifications pete?):P Just hope the clutch holds up till then.
Despite the the objections of a few ppl, i think the skid pan is a great place to learn to drift and learn car control. Hell of a lot safer than on the streets, way too many close calls lately.:eek:
Hi Peter,
Finally I have confirmation from Eastern Creek on the April 6th day for you,
the day is on!
I have attached a booking form that ALL drivers MUST fill out & return to
our office or they will not get a start.
No need to fill in the credit card area as I believe you have taken
depsoits?
We will require 50% deposit for all drivers ASAP as Eastern Creek require
full payment prior to confirming booking. I have done this to secure your
date.
I will have 1 instructor on hand to assist with the control and safety
during the program.
We shall begin at 9.00a.m SHARP and conclude as per Eastern Creeks booking
rules at 5.00p.m.
I'm sure your guys are looking forward to a fun day and that is what this
venue delivers, believe me!
Cheers for now
Aaron M
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
