hi all, i had a look at an r33 today, it was at an importers in melb, jumped in started it up and noticed the airbag light on the dash didnt turn off, well, to be honest i didnt notice if it came on at all, but what i did notice was that it was on permanantly although really, really faint..... would this be any real cause for concern??? also, on a different car i ran a check on the vin, now this number contained xxxECR33xxx so i'm assuming this is model specific ie. r33 however when i ran the check, it came back as an r34, is this likely to be a typo???
https://www.sau.com.au/forums/topic/104530-buying-an-r33/
could be just a bad connection in the wiring, or the airbag if f**ked, ecr33 is r33. How was the rest of the cars?? good? good price? if your worried about buying a lemon take the car to a tursted machanic to be checked. (should do this any ways and done use one the car yard asks you to.)
https://www.sau.com.au/forums/topic/104530-buying-an-r33/#findComment-1924408
thanks, it had the stock wheel on it, the light was on but like i said it was dim, kinda like when ya have a bad earth somewhere i guess... i'd be gettin it checked out and i checked the other ones numbers on the raws site, it came back all good and the nubers all match so i guess it was just a typo, but again i'll look into it more when the time comes
https://www.sau.com.au/forums/topic/104530-buying-an-r33/#findComment-1924736
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
