Hey guys, I saw this boost controller on the Hikari website and a few others, yet i havent found any other info on them in regards to how they preform compared to the way more expensive Jap brands. FYI Hikari are sellin them for 320. Thats a fully electronic Dual stage boost controller that has in cabin control. Seems to good to be true. It also looks quite nice and looks like it would fit snug in the position of the ash tray (which is good as im not a smoker).
If anyone can shed any light on this product whether its reliable and how it preforms, etc, it would be greatly appreciated.
Thanks
http://www.hikariperformance.com/new_electronics.htm
(scroll rite to the bottom)
https://www.sau.com.au/forums/topic/10481-hybrid-electronic-boost-controller/
I was told but am not 100%sure that they are like a electronic version of the turbosmart type 2 stage bleed valve setup, so they are not as accurate as controlling boost like good elec ones they just give you control in the cabin.
They are nothing like the TS twin stage they do run a micro processor
seen in two cars now work well but you need to have a map sensor of some type ..... like you need to tap into say the std dash map on r32/33 but on somthing like a s13 you'll need to hunt a map sensor down
I sent power digger an email.
Heres what i sent:
Hi
I wondering if you could supply me with as much info as u can on the Hybrid fully electronic boost controller. How does it work through the microprocessor? Is it like an AVCR, or not as indepth and efficient. Will it hold high boost levels, and will the boost levels spike due to it being a bleed valve type boost controller. Im very serious on buying one, just want more info before i make my decision.
Thanks
Dean
And heres his reply
thanks for your interest it has a micro built in and by sensing the boost signal the micro calculate the right boost amount
in other words it try to bring the boost up to preset level as soon as possible and soon after it reaches the preset boost it regulated it
never over shoot
beside it is not a bleed type valve it is a proper 9 bar solenoid valve that uses in many other Japanese boost controller
Thanks
  • 3 weeks later...
Hi all,
I have installed the hybrid boost controller. I have to say it was the easiest ebc install(just three wires, the same three that run to the factory boost reciever in the engine bay) i have ever done!!
Very easy to tune, just set the dials for hi/low boost.
On the road it holds boost and at 20psi is only only slightly shaking the needle on the boost gauge (not more than half a psi either way.
As for brining boost on earlier I noticed a little differance
install 9/10
tunability 10/10
boost holding 8/10 (twin solonoid would have been better)
Appearance 4/10 (only one blue led and no screen as per avcr)
All in all not bad for $325 delivered
  • 3 weeks later...
Hi There,
I also noticed the "powerdigger" at UAS (for $380).
Seems like a really good buy.
Quick question for those who have installed it.
- Does the car fill "jerky" when on full boost as some one mentioned that is was changing half a psi up and down (at 20 psi).
I am only planing to run 12 psi, will I notice it? How smooth is it under boost?
- when it comes to installing it, where is the "map sensor" or "boost sensoe" what ever it is called... I should have no problems installing it just need to find that boost sensor (for an R33 gts-t)
Thanks for your answers.
Regards
Rob
Hi Rob the car is not jerky when on boost, even though the boost needle is moving. When you get the intstructions it has a picture of the boost sensor and how to wire it all up. The boost sensor should be on the left hand side of the firewall. easy to spot if you know what your looking for.:)
If anyone else has installed one please write your comments, as I wonder if it is any differant on a smaller tubo, unlike mine which has a fair bit of lag.????
Ps go to hikari they are $325 delivered
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
