are these the D1 style drifters? at work and cant open the vids. If so, i bought Ken Nomuras ER34 Blitz D1 drift car from Japan recently. The Battery doesnt last long, but they are good fun otherwise. SO many aftermarket parts you can buy for these things.
New wheels, coilovers, bigger batteries, bigger motors, sticky tyres etc etc..
i cant seem to find anyone in australia that sells though rc drifters, looks like a lot of fun!
These have been around for a while. You actually modify a remote control car to drift by changing the tyres. Those look like battery operated cars you should try with petrol power heaps more power.
Yeah just get a RC car of ebay or somthing, i think most drifters are electric not the petrol ones, i find the elexctrics work heeps, better, you can jsut put PVC pipe on the back wheels and it works perfectly, my mate and me bought a Awd petrol one, put a 2speed in it, and put pvc pipe over the back wheels, the pipe most hardware storse will give for free as its only a tiny bit, needed.
Edited by Michael_1882
normally they are 4wd cars with drift rings around the tyres or cheapest option is cut up pvc pipes and glue it on the wheels.
if you want cheap way go for the Tamiya TT01 or TB02 with PVC pipes.
if you want the good stuff go for the Yokomo Drift package, these will give better control and hold difts for a long time. (more info go to yokomousa.com)
If you guys are interested, I import these on special order.
Hey SXR
Yeah i would like a set if you can. How much with postage to Melbourne, 3038?
Hi All,
A company in the USA called Yokomo specifically builds 1/10-scale electric RC drift cars. They work by placing hard plastic / rubber rings on the rear tyres which, combined with the torque of the 540 electric motor allows you to drift them.
They all come with clear Lexan plastic bodies which represent cars that are or have plied their trade on the D1 circuit in Japan.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJDB8&P=ML
This link should answer a few more questions. Tower Hobbies does ship to Australia and they are far cheaper than most of the Aussie hobby shops (sorry to say that, but buying in bulk has its advantages, so does a lack of GST :( )
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
