Item: white 17" Enkei RP01's lightweights! (came off a s2 r33 gtst)
Item Condition: pretty good condition, abit of gutter rash on 1 wheel nothing that cant get fixed though.
Reason for Selling: dont really need them no more using stock wheels atm.
Price and Payment Conditions: $700 cash pick up!!!!!!!!!! price drop from $1100!!
Extra Info: 17x8 front w/ toyo tyres (pretty much new tread) & 17x9 rear w/ falken tyres (pretty much gone on the inside cuz of camber, but outside still liek 30%). +38 offset
Contact Details: PM me. or email [email protected]
MORE PICS ON 2nd PAGE!!!
Edited by hanyou
not sure mate, but it suit r33 gtst series 2. ive put it on my mates soarer it fits as well.. hope that helps
Not really. I want to know if they'll fit an R32 GTSt so if you can find out the offsets i might be interested.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
