Hey,
I just put new wheels on my car and went to change my avatar to a new pic.
however it wont upload it says its too big. Went to put my old one back on and it says its too big also.
Has this recently changed?
I cant upload any pics of my car as they are all around the 6to 700kb mark and it says max 100kb
Is there anyway around this so i can put a pic of my car as the avatar again?
Thanks
https://www.sau.com.au/forums/topic/105047-avatar/
Did you read the posts in this pages before posting? :)
Covered before as there were changes, hot-linking/sizing changes made before chrissy due to abuse
http://www.skylinesaustralia.com/forums/in...showtopic=98175
:P
No sorry mate i didnt
Thanks for the link, i will read now.
Cheers
https://www.sau.com.au/forums/topic/105047-avatar/#findComment-1933998
