Hi
I just moved to Canberra from Dubbo. Down here to do some uni. Some of you might have seen me driving around already as i've seen quite a few lines with SAU stickers on them getting around.
Anyway i drive a R32 GTS-T with a Do-Luck body kit on it. The car can be seen here http://www.skylinesaustralia.com/forums/in...howtopic=101384.
So do you ACT skyline folk get together for cruises or anything very often? I'd love to come along and see a few other lines. Back home i had the only 32 in town until just recently!
https://www.sau.com.au/forums/topic/105065-howdy/
We usually meet on a friday night at the Museum, but as of late there hasn't been much interest in that. stay tuned as we get it back up and running with 20+ cars a night!
https://www.sau.com.au/forums/topic/105065-howdy/#findComment-1935056
Well i guess its not really uni as such. I'm at CIT. Hopefully there'll be some cruising going on soon. Everyone loves a good old fashioned cruise!
Hey chintami seen your car at CIT the other day. Looks tidy!
https://www.sau.com.au/forums/topic/105065-howdy/#findComment-1936530
Ok....or everyone could completely forget to mention Tuesday nights???
We meet every Tuesday at the Jerrabomberra Tavern for trivia and a get together, you're more than welcome come!
THAT IS THE EXACT KIT I WANT, how much did it cost and where did you get it from?i sure hope it's not an original, otherwise you'd be taking out a secoind mortgage to buy it!
https://www.sau.com.au/forums/topic/105065-howdy/#findComment-1936582
Hey Simon,
Met you the other day when you came into Autobarn. I was the guy you first talked to with glasses. Saw the car outside, looks very nice.
Not sure if you realise, but I also own a maroon R32 GTS-T with a big front mount. haha freaky aye
https://www.sau.com.au/forums/topic/105065-howdy/#findComment-1937132
Veilside R33 its not an original kit. Its a replica i got from a mob in Perth called Works Auto i believe. Its an extremely well built kit as in strength etc but it doesn't quite fit that well. It took quite a bit of modification to get it to fit the car properly.
Also the kit is rediculously low! I went for a drive through Manuka the other day and got beached on one of the speed humps there. It was a little embarrassing!
To get the kit from works auto without the optional spoiler was about $1500, a fair bit cheaper than a genuine!
Also i might just come along Tuesday night, trivia and meeting other skyliners never hurt anyone! What time is it on?
NathR32 yeah Lee was telling me one of you guys owned an R32 but he said it was a different colour to mine! I figured it would probably be the same. Done much to yours besides the front mount?
chintami i wasn't trying to ram you in the carpark today either!! I swear! Was just trying to think of too many things at once!
https://www.sau.com.au/forums/topic/105065-howdy/#findComment-1937981
Bahaha :) sorry had to be done i guess you need to take it sidways over the humps. Though i didnt think the manuka ones were all that bad :)
https://www.sau.com.au/forums/topic/105065-howdy/#findComment-1938160
hahah yeh sure <_< i was thinking if he doesnt notice me we are gonna crash, didnt no whether or not to wave in a situation like that so i just smiled :) Prob see u @ school today! btw im lovin ur car, especially the ride height!! :)
https://www.sau.com.au/forums/topic/105065-howdy/#findComment-1938181
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
