List of parts...
R33 Std Dump
R33 Std intercooler
R33 Radiator ***SOLD***
R33 Power steering rack ***SOLD***
R33 Fan
R32 Turbo - Great condition...
R32 Exhaust Manifold
R32 Alternator
R32 Crank Angle Sensor
R32 ECU ***SOLD***
R32 Air Fuel Meter
R32 Coil Packs x 6
R32 Ignition Pack and cable ***SOLD***
R32 Std Injectors
R32 Flywheel ***SOLD***
R32 Wiring Loom
R32 Fuel Rail
R32 Intake Plenum
R32 Fan Belt Pulley
R32 Fan
There is pics of most the parts...
Please give me offers.... i have to sell this stuff, but please no REALLY stupid offers
PM or call 0409875864 Troy
https://www.sau.com.au/forums/topic/105384-need-to-sell-list-of-parts-for-sale/
im just goign to rip it apart with him, and check it out...
ill get back to everyone in PM's when i have them and ill give prices.
Please post your interest in items here
pretty much we arent wasting a heap of time or money on it, so... considering he said he had one doing the exact same thing, and thats what it was.
I dont really know.. so i have given up on it :rolleyes:
Just trying to get some money back from it, even if it is minimal
Mine had a miss and it was the computer that burnt out the igniter pack with to high a voltage. I had no fault codes. Sounds like the mechanic many not know what he is doing. I agree with the other guy about the comp test.
Could I have a price on the rubber inlet from turbo to afm.
well i guess ill find out when i rip it appart...
Get back to you on the flywheel...
Not sure if i have the rubber part... think i may be using it, will find out
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
