Yeah, but the question is can you ever fit 65L into the tank :P
I usually fill up before the orange light turns on, or just as it turns on. With the new fuel pump and upgrades, I'm afraid to even let it sit at the 1/4 mark - it's always above half tank.
Must get a tune soon :(
  • Replies 77
what power you making bunta?
retune :P
wifey wont like it;
ive already spent hundreds of dollars on tunes (switched exhaust, retune was another 300 on top of the origianl 600)
surely for that amount of money, it wouldnt just be a power tune :(
was done at mercury
Spooks I make 200 rwkw on the dot, However I think that having the RB25 in the lighter car (R32) would lend its self to better ecconomy, I find a lot of the time I am using around half the throttle that I used in the R33 for similar accleleration (R33 also made less power)
How could you not fit 65L into a 65L tank.
When the light comes on..you should be able to drive approx 100km more before the car will stall.
I'm just curious as to how people are measuring their distances. Surely you don't just fill it up and then read the odometer when the light come on.....that's just silly.
The only accurate way to measure the right distance is to fill it up completely to the brim and then drive 100km. Then pull into the nearest servo and fill it up to the brim again. Note down the number of litres you have put in....it's as simple as that.
The car is heaviest on a full tank so the fuel economy is its worst when the tank is full. Don't cain the crapper out of it for 100ks either, and don't baby it...just normal driving...boost it regularly. Then post up your results. I am willing to help those in need but no-one has taken me up on the offer yet.
The only reason I suggested the tune was because on my old r33 gtst I was pushing 300kms out of a tank, thanks past the light and waiting till it coughed.
Anyway I bough a SAFC and took it into Mercury for a tune and BAM gained 15rwkw and consistently got 550-600kms out of the tank!
My problem is that the skyline only get driven hard. If I was going for fuel economy, I'll just drive the office prius, it get over 1000k/tank and take 500 metres to stop from 100k/hrs. Tyre are as hard as Steel.
But if you have ongoing bad fuel eco, get a smoke test done and a good tune will fix all. but $500-750 in difference of fuel eco, buys alot of fuel. Oh wait I don't have to pay for mine.!!!
I had a similar problem with bad fuel economy and fuel smell.
I traced the problem back to the aussie fuel filler/nossle from the compliance process. seems the dodgey bastards hadnt fitted it properly and it had become slightly loose and alot of fuel was evaporating whilst the engine was running.
I simply removed it, cleaned it down and used a strong fuel rated sealant such as sikaflex. I got alot better fuel economy and lost the fuel smell.
matty
Hmm maybe a SAFC is the way to go.
I have a stock GTT and was getting 400-450kms (mixed city and freeway) before the light came on, a few months after now getting 350 to maybe 400, pure city driving though. Dont know whether this sounds right but I do know other GTT's, especially modded ones are getting more. I drive OFF boost almost 99% of the time.
So yes, Id like to know whether there is a fix for this? perhaps a SAFC might be the way to go. Ill also chuck it on the dyno to see how the figures turn out.
That's deffinetly the best way to measure your fuel consumption, i did a couple of Thursday's ago had 11 pound, 35k's highway the rest was fairly spirited, pulled into the servo and got 12.3 L i was pretty happy with that, is this more what your trying to get spook's
within the powerfc, drop the injector duty cycle down by xx %
remember, it will run leaner across the board (so more knock, perhaps?), but is the easiest way of 'retuning' it without taking it to a tuner ?
Anyway, i couldnt be bothered reading all the 3 pages, so it may help ?
Or drive it off boost. with my car i managed 450 city kms when keepin it under 0.2 bar of boost. boring as hell to drive. Mind you the other day i ended up going for a bit of a thrash and did 200kms on a tank (whoops)
oh and managed to chew up most of the fuel when i was at oran in under 100kms :P
happens when your duty cycle hits around the 92% mark on 700cc injectors
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
