u could just tell us what causes bad fuel economy
I have two thoughts now, if your afrs are near on that 12.
The 12s are on WOT tune, so everything in between that and idol sucks ducks nuts. meaning drinking fuel as you dont drive round with your foot flat all the time.
2nd thing could be a fuel leak still, which would mean it could still be tuned properly. Just the fuel isnt all making it to the engine.
  • Replies 77
yer, it doesnt seem to matter whether i boost it or not, my economy is still bad
which leads me to think its something else
i would hope that the tune was done propperly, coz it cost a f**king fortune, surely i shouldnt have to tell my tuner to tune not just for WOT but for normal driving as well????
the economy was bad with the stock ecu anyway, so im pretty sure that the tune, while it may not be helping, isnt the issue
there is always a strong fuel smell when i reverse, but i can never smell fuel in the boot area after running the car
im interested in the evaporation issue the aussie fuel filler/nossle issue that was bought up before, and i pm'd the guy from nissan silvia who fixed his economy by replacing his charcoal cannister (he reckons he did nothing else) so, im going to hook mine up again also
my o2 sensor is brand new
ive had a heap of fuel hoses replaced as it was discovered that they were perishing (along with every other hose in my engine bay that ive had replaced)
this problem just seems to common, so many of us suffer from such bad economy
i want to know what causes it and how to fix it
spook i have no canister and i can get a bit over 400km with normal driving (which includes a bit of boost)
i got 350km last tank and that included a whole lot of boosting over glorious
can you pull up o2 sensor readings on your pfc? have you cleaned your afm recenty?
yer, ive been watching the o2 sensor readings on the hc
seems to be working correctly
i havent cleaned my afm
woudl it being dirty affect its readings?
ill check and see what sort of voltages its reading;
Maybe get a PFC retune?? My new car has a PFC and I get awesome ecconomy (411ks out of 35 L ;) ) The new car gets no fuel smell at all where as the R33 you could smell it all the time (Stock ECU) I think engine managment would be the main factor that effects fuel ecconomy
damn, some of these posts are crazy, the other day i got 350km with 36litres, and i have a stock ecu, with other mods, i have a power fc waiting to go in, these posts are sorta scaring me puting it in and tuning it :)
Spooks,
Go back to MM and get them to look at it firstly. I think that you should give them an opportunity to explain.
On a side note I had my PFC tuned there and am quite happy with the fuel economy, granted I mainly drive it on weekends and it is warmed up before every drive and then cooled down...
yer, im not convinced its the tune
fuel economy was bad before the pfc (350ks to a tank, with just exhaust, dump pipe, fmic and plenum)
im going to get my mechanic to check a few things out for me next service and see what he comes up with
then im going to get in touch with elite and see what he says
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
