First to lay down the background, have a read of this thread about the ATF coolers.
http://www.skylinesaustralia.com/forums/in...showtopic=59399
Now, I can offer these coolers 678 DC coolers with 3/8inch fitings for $118 each plus postage and handling. Pickup available in Blackburn area in Melbourne, postage anywhere in Australia also available. Postage costs will vary. Handling fees will be fixed at $10 for each item (to cover bubble wrap, packing materials, going to the post office etc).
Worst case scenario, to the middle of nowhere, postage will be ~20$ (Thats like postcode 0830 in NT). Sydney/Adelaide should be around $10, Melbourne $7, Brisbane $13.
These RRP for $150, but you need to go pick em up etc, they are not delivered to your door (yes, i am THAT lazy :))
I dont need to explain the product here, just read the thread above. Suitable for any Auto trans
So, who is interested
1. humble - picked up
2. bwilkeson - delivered to adelaide
3. pkblade - delivered to adelaide
4. skidkid - 2 units delivered to tassie
5. wagon - delivered to melbourne
6. AMS - delivered to country NSW
7. Nightcrawler - delivered to adelaide
8. MR_RS4 - delivered to brisbane
9.
10.
Once we know who is interested, I will send out the details of where everyone will need to make the payment. But for now, lets get some names.
https://www.sau.com.au/forums/topic/105610-gb-davis-craig-678-atf-coolers/
Updated, will close the group buy in 1 weeks time on Wednesday 22nd. Then we will order and probably have them by the weekend. Then we can ship them off first thing monday for everyone.
Sure, 100%. Just thought the drive might be more expensive then getting it posted to you is all.
Obviously we will arrange pickup/delivery etc next week when I got buy them.
Anyone else interested?
Sent out PM's to all that were interested. Let me all know how it goes, cheers :P
Thanks, look'n 4ward to it!
Will have to scoure the thread 2 make sure I install it correctly!!
As far is I can see, and the info given to me by Abo Bob etc, there's nothing to it Bendan. If you want to have a 'fitting bee' in my garage one weekend, give me a yell. Probably easier with 2 guys?!
