Hi all , there are soon to be some new Garrett T3 flanged integral gate exhaust housings in .63 and .82 a/r for the GT30R/GT3540R ranges . They are to be available in April 2006 but no details yet .
This will help those who want to use GT30R's and GT3540R's but without the external wastegate . The rumor is that the dump side will look something like the Fords XR6T's GT3540R housing .
More soon I hope , cheers A .
This has been in the spanners for well over 2 years now, it should have been done earlier, but GARRETT have been constantly changing cast manufacturers, thus the delay
As disco stated, late April/early May
The backorders on them are HUGGGGGGGGGGGGGEEE to say the least
Thanks
Tarek
RACESPEC
LOL , don't know ATM . The turbo is a long way off yet but with some recent research into GT3240's and some of Garrett's GT bush bearing turbos it seems there are 82mm GT40 compressors in 50 , 52 and 54 trims . I feel the 56T on Garretts GT3540R is a little big for the power or I should say torque I want so its a waste of turbine energy spinning something thats never going to achieve its potential . Far better to use the compressor wheel trim that suits my needs as it should be more responsive and increase turbine efficiency a bit . The $64 question is can the wheels be bought and is the back of the wheel the same as the BB version ie flat back or tulip shape and so on . Brett from GCG tells me they can drill/bore the centre hole if necessary so if the bush bearing shaft is smaller its not a problem . If I'm lucky and it bolts straight up I'm laughing .
Another thing to look into is this extrude hone process , the Americans say that noticable gains are had from extrude honing the turbine housings . This is not so much from a making the passages any larger but smoothing them out which aids the flow rate but not at the expense of gas speed . Its supposed to give a few more points of measurable turbine efficiency . Some of the turbo sellers will do this in the US at an extra cost so its an option if you buy from them . It could be done here but the set up cost is not cheap and I have seen the result of just a bit (lot) too much taken out .
I was told about these C117 compressors about 18 months ago , like the later GT40R has , and there is supposed to be new turbine designs on the way but when is anyones guess - they may already be out there in truck turbo's .
So I can wait and when the car eventuates the goodies get stashed away as turbo technology marches on and it all comes together .
I hope I can resist the temptation to play with the RB20 - maybe just an rb25 turbine housing - see I'm hopless !
Cheers A .
For Cubes hot off the press , Brett tells me there is an 82mm 52 trim BCCW18C compressor (59.1mm inducer) available . Just have to figure how difficult it is to fit and if HKS's idea of using the .60 a/r TO4S cover for 50 and 54 trim 82mm wheels is the go .
The amusing part is that with these GT40 compressors the inducer sizes are as follows .
50T = 58mm
52T = 59.1mm
54T = 60.3mm
56T = 61.4mm
So only 3.4mm the difference 50 to 56T though its supposed to make a very real difference in the way they load up the turbine particularly initially . As I have mentioned before the difference between a 52 and 56T GT30R is 500 rpm .
Cheers A .
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
