Hi Guys and gals,
Where do I get the lock nuts for HR Racing Wheels? I got the Barri-Nut lock nuts - but they are not the right size. Im guessing that only the specific HR Racing lock nuts will fit my rims. Can someone tell me where to get them in Vic?
Thanks :P
p.s I have attached the pic of my rims as well - if anyone knows where I can get hte right lock nuts - please let me know :D
https://www.sau.com.au/forums/topic/106063-wheel-lock-nuts-for-hr-racing-rims/
There is another thing thats bugging me about the car - the turbo timer on it is a Starbo RS-1500 timer (apparently its an auto/remote start combination with the turbo timer) - the thing is its all in japanese. Its got 6 little levers that is either up or down - lever 1 says "ON" - but it doesnt do anything. Sometimes it works for about a minute, other times it doesnt at all. Can anyone shed some light on this as well. im guessing I will need to get another turbo timer - but I have to wait for a bit. If anyone has this, or knows how it works, please let me know. :D
Thanks all.
if it works on n off, try switching the key position to off without the door being opened or your foot on the brake pedal, cuz sometimes these are set to bypass the turbo timer. That is in the event u dont want the turbo time to be running, you can jus open the door or have your foot on the pedal and switch the car off....
about the right size lock nuts, just go to any bob-jane t-mart, they seem to have everything....good thing is, if it doesnot fit they give a replacement then n there....i have been gettin all the work done from the oakleigh one.(corner of prin hwy and warrigal road).
Ok, guys - i got the turbo timer running - but even when I am driving normally (lets say for about 10 minutes), and after i get back home, turn off the engine - it keeps running for about 2 minutes. Is this normal? or have I actually got a faulty turbo timer?
If this is indeed faulty - whats the best turbo timer to get. I was told the Apexi turbo timers are excellent, and cost about $120 to buy.
Thanks in advance.
thans for the reply nate - its just that I went to get pizza (about 4-5 mins from my house) - I stop the car and it was on for 2 mins - so i was just thinking -thats a bit excessive....
what tt is it? if the instructions are jap chances are the auto mode isnt hooked up right? AFAIK, its just 12v/ign/acc and thats it i think, i have a manual one which is set to 2mins all the time.
as i put on one of the posts above -> its a Starbo RS-1500
Its all in japanese - and I have no idea what the 12v/ign/acc is......:D
the only way I will find out i guess, is after i get back from a long drive.. and see how it goes - or I can post a pic of the turbo timer up tommorrow....
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
