Yeah its the t78-33d with the smallest 17cm exhaust housing, i had a look at it and damn its in good nick. If i can get 1 bar by 4000rpm with cam gears tuned for midrange i should still have a big power band (4000rpm).. When its on i'll get matt spry to try get as much midrange and tourqe as he safely can, should be fun. :ban::pwned:
I was going to get that from him hey,. i was contemplating whacking that turbo instead but i realised its going to be laggy for my set up... so i went ahead with the GT3540.. with the .82 housing..its still a little laggy.. not spooling till 4000rpm.. but when it kicks,.. it kicks on hard.. just waiting for my cams and bigger fuel pump now.
it should be the same with the rb26..but with the right set up..it shouldn't be a problem.. but eitherway.. it will be fun. :rofl:
  • Replies 461
Interesting you think the GT3540 is laggy, I would have thought it’s too small for a 2jz. We’ve played with a Supra that had a GT40 or GT42, I forget, never the less, far from a lag monster.
Had no issue’s frying his 315 tires on the highway, and all he had was fmic, fuel system, cams and ecu, would have been making boost the same rpm your 3540 seems to be.
Thats prolly me, though my rims dont have white centres. I'm pretty sure i'm the only one with a midnight blue gtr on the coast.. (only %5 of r32 gtr's are midnight blue in colour from the factory..) Thr caps on my rims are alloy in colour, same as the spokes. Easiest way to spot me is i have a www.skylinesaustralia.com sticker the full lenght of the rear windshield up the top, then you'll know its me. :D
Yeah must have had you mixed up with another blue one I've seen in Alex a bit.. Had work rims with white centres.. Stopped to have a perv of yours the other week :D
Edited by Drift_Limo
dynamix: did you buy the t78 off that dude named buttocks with the black silvia with pumped guards? If so, I was contemplating buying it for my 1jz as well. Decided too much work as it is only 1mm larger comp wheel than what I currently have.
yeah,. i am not aiming for big HP,. just for street driving.. so the 3540 is the way to go for me,. i was getting the T04z with the same .82 housing but couldn't find one then..so i settled for the turbo i have now.
depending what size exhause housing the GT40 has..they do spool pretty quick... T78 however would be a different story...they mainly built for Top end power.. close to 5000rpm.
Hey chris,. yeah he bought it off him... i was also comtemplating getting it but decided to stick to my set up now.. and i already had my custom t3 manifold made.
3540 will spool pretty quickly and should be a good streetable turbo. On my old 25 the hks 3037s spooled quickly (it had cams etc) and had decent pull power from around 3500+ rpm....good for fun and with the luxury of a stronger bottom end and decent boost....well lets just say i had 265's and 1st, 2nd and 3rd were pretty fun gears!
What car you driving now? I remember your old 33 when you took it to adam hoyle's and showed her off.
yea i remember, that night was fun....driving home at like 12am on the highway after it'd rained....haha overtaking a truck in 4th gear on boost...I think he was unhappy when I was wheelspinning past him...it was unintentional but i dont think he got the idea. Anyway atm im not driving anything, i dont have a license (thanks to forgetting my seatbelt) lol. So i have no need for one, but when i get it back it will be a toss up on what to get..i dont think it'll be an import though. Not at this time anyway.
Edited by 33NIZ
Is your GTR rust proofed?
It is one of the first things I did to it. I will be put a cruise control into it when I get the time to.
have you protected your car?
I have found rust on some new cars before.
Thats prolly me, though my rims dont have white centres. I'm pretty sure i'm the only one with a midnight blue gtr on the coast.. (only %5 of r32 gtr's are midnight blue in colour from the factory..) Thr caps on my rims are alloy in colour, same as the spokes. Easiest way to spot me is i have a www.skylinesaustralia.com sticker the full lenght of the rear windshield up the top, then you'll know its me. :sweat:
yeah but you used to have white spoked rims on it,with a polished lip, then u changed rims. i think hes talking about when your car had them on matt.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
