Big carl has the 6 blade GT30 not the 7 blade that you are running Mafia (from your other post about your probs).
Carl: are you still running the rb25 hot side? I have the same turbo (HP in a box) and got 248wrkw. I am about to put the vg30 hot side on so I dont have to run 19psi...
its definately 500hp turbo checked the id tag with whats on gcgs web site. i emailed gcg yesterday about changeing over the a/r .63 internal wastegate for an a/r .82 internal wastegated one and mark larden from gcg confirmed that they can do it for $450 exhange or $600 outright. also that i should pull 290 to 300rwkws but with an extra 500 to 700rpm in lag or spool up! stuff that i say! well at least i know now. think i will leave it as it is. thanks for your input guys.
So are you running the rb25 Exhaust housing mate? That's what I though they came with from HPInABox?
Anyway it seems to me like the 7 blade turbo with the .7 comp housing is no good with the VG30 zaust housing. I am going to go with the vg30 housing with my 6 blader GT30 and see what happens. Unique Auto Sports have been selling these for a couple of years and seem to be getting 250 - 260 rwkw at around 16 psi which I am aiming for considdering I am currently getting 248 rwkw with 19 psi using the rb25 zaust housing :)
the 7-blade wheel has never been a good match in them :D
its anciet.
Although some people around will tell you GT30's done come with a 7-blade wheel... but this is just another post to prove people are slightly mis-informed
rb25 exhaust housing = 281rwkws.
Not for me big fella. 6 blade GT30 like yours and rb25 exhaust housing = 248rwkw. However I have an OEM manifold and no cams etc... + only 19psi ;)
Edit: I am putting on a z32 zaust housing (well its actually a r34DET one which is the same). I am hoping to get 250-260 rwkw with 16-17psi...
Edited by GunMetalR33
yes ive got the six blader. i had 260rwkws original tune with this turbo but i wasnt running cams , just aftermarket manifold. awesome turbo, power comes on very hard at 3800rpm!. i drive on low boost most of the time but even with 14psi ive got almost 250rwkws. i get 10psi by 3000rpm on low and even earlier on high boost! cant wait to hit the strip with my nittos...
Edited by bigcarl
Big carl: are you still looking for a new manifold? Are you interested in selling your current one?
I think my smaller power level is due to me having to use 2 spacers on the Exhaust housing to fit the comp cover next to the manifold. These spacers are not exactly the same size and the one closest to the turbo has a smaller inside diameter and acts like a exhaust baffle...
When I get the r34 housing I will get 1 bigger spacer made up that is the right size.
Hey Gun,
how much do UAS sell the VG30/R34 exhaust housings for?
Garrett should be selling their new T3 flanged integral wastegate GT30 turbine housings in 2 - 3 months , worth waiting for I reckon . Don't know exact time frame - maybe sooner if imported direct . HKS sell theirs as well for the GT3037 Pro S .
Cheers A .
Cheers A .
disco,
i'm actually looking for a VG30/R34 (A/R .63) housing to suit my t3 turbo sitting at home, which will be going on my new car soon. :)
Hey Gun,
SSSssshhhhhhhh, quiet about the whole vg30 zuast housing being the same as the r34 housings :)
UAS and other importers do not know that they are the same, if they find out the price of the r34 housing will go through the roof.
I talked to them about getting the z32 housing before I knew the r34 was the same and they said that they could not get it anymore, too hard to find...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
