i have a sticker like that. A drifter gave it to me one night. I got a friend to translate it and she told me it says: "the noise a car makes when it goes past"... lol i dunno how they captured that!
this one though was possibly written by someone who doesnt speak japanese. are you sure it originated in japan and not the US of A?
カ千やマヤホネ would be good thousand mountain (something) work? As the others said its bad japanese whatever it is, but it could be trying to say that the person who wears the sticker is "Teh Awesome Touge Master!!1ONE!"
イケダさん!このシールについて、どういう意味か、あなたの意見を教えてください。
Hopefully he'll see this thread... ;)
My moneys on: "Bollocks".
ok i put some thought into this one
山 / ヤマ (backwards) may be something to do with a mountain as yama means mountain, or a monuntainous area etc
骨 / ホネ means bone, a joint, and it can be used with other japanese to mean things such as
- a man of spirit
- a difficult job
- a hard job
- have trouble
- a hard UPHILL task
- to work a person very hard
- to spare no pain
- to take endless pain
- to make an effort doing
- exert
- ones self
- easily without trouble
カチ means worth, merit a value
and be used to things such as
- something is very valuable
- to deserve something
- a value of learning
- artistic value
セ can mean the rear of something
hence 山のセ = a mountain ridge
at this point maybe a few things could be backwards ...
セチ = strong / maybe worldly wisdom
so i think either it means
reading it backwards
1.) do you have wisdom of neho mountain?
2.) to try your hardest and learn/ deserve ...何とか... its going to be a difficult job
3.)
Pass... it might be just some kind of made up slang... hashiriya are famous for doing that
rezz Edited by akeenan
wait ive had another thought maybe it could mean having a drug addiction for a thousand armpit hairs ..... ;)
with really bad japanese
but on another note
it could have something to do with intellect
so maybe intellect of the mountain and armpit hairs and it being a difficult job and possibly it causing trouble along the way and its going to cause some trouble and its going to take a lot of effort and somone will exert themselves (me)
serious just get a sticker that reads めちゃめちゃ , or ばか言う
but im also wondering about the ャ
maybe it means catch .... me(?) 。。。。何とか 。。。will be a difficult job/ task anywhere/ various places ... 山のセ = at the mountain ridge
Being written in Katakana would tip you off its probably not a japanese word (and my japanese student sitting next to me) and since no one understands it, I will also go with nonsence.
this is true but it could also be to emphasis the meaning ... which is certainly not 100% 日本語 (japanese)
Edited by akeenan
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
