Item: R33 Trust sideskirts and rear pods
Item Condition: As brand new
Reason for Selling: Getting different kit
Contact Details: 0422 433 414 or [email protected]
They been sanded down and ready to paint.
Asking $350
https://www.sau.com.au/forums/topic/106583-r33-trust-sideskirts-and-rear-pods/
3 fiddy for trust skirts and pods.. i'd at least ask for a pack of skittles too!! these look sexy as on your 33!
goodluck with the sale pav. free bump
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
