anyone know the forum user "cj"?
would save me hunting him down... lives in adelaide.
if so PM or email me.
If not i'll just track him down myself.
in regards to this... http://www.skylinesaustralia.com/forums/sh...&threadid=10218
https://www.sau.com.au/forums/topic/10660-man-hunt/
doesnt matter i just found his address and phone number... seeing as his DOB in his profile is 84 one would guess that in the whitepages its his parents... might give them a call and see what they have to say.
https://www.sau.com.au/forums/topic/10660-man-hunt/#findComment-171913
Here's a cj quote from this thread:
http://www.skylinesaustralia.com/forums/sh...5572#post115572
makes three of us....come on ice180 pls reply I want headlight will be overseas for next three weels will be bak february 4 so better hear from u by then
Looks like he's just gotten back from somewhere in Asia. The amount of fake sunnies that come from there is unbelievable. He has rorted you bigtime. Sorry to hear and i hope you get the prick.
https://www.sau.com.au/forums/topic/10660-man-hunt/#findComment-172520
