Hi guys, I'm from Malaysia and in our forum, we have a hot topic about this...anyone of you guys tried it before?
The question arises when an A31 was smoked by an M3 on a Malaysian highway on top speed, and because of the car age, the chasis is a big issue whether or not it will support up to 300kmph of G-force, even if the car has a full anti-rollcage and strenghtening bars in it....
currently the vote is 90% of the Ceffy owners saying it was impossible to chase down an M3, M5 is of course out of the question...
I'm with the remaining 10%, 'cause I've tried it before...what do you guys think, pls share your ideas, comments and experiences here, thanks in advance!!!
I don't think 1JZ conversions are that common in Malaysia. Last time I was there most of the guys were running RB25DET's and RB20DET's. Thailand is the capital of 1JZ conversions.
5000rpm in 5th (s13 engine and gbox) with my car has been done. I'm not sure how fast that is but at that speed with foot fully off the accel it took 7 seconds or so for the speedo to get back to 180. Done without a wing.
So with a huge wing, some racing decals and better tyres I don't see why a cef can't do 300kmh.
I'd prefer to be in the BMW though.. Just something inherently safer about a german made car designed from the factory to test the limits of human terminal speed courage/stupidity :D
Gearbox and diff would be required. To lengthen range.
I have 'seen' 6700 in 5th and it was off the speedo for about 30secs to a min to get to that. Est speed around 220. So with a little more it could make it.
Goes from 120 > 180 very quickly once the turbo comes on and engine is revving. Probably 5-10 sec acceleration time.
Would be a monster if it wasnt revving so hard. This was with standard everything. Never been in an M3 / 5 so not sure how fast they are. :P
I'd be quite happy to drive a Ceffy at 250+ with standard chassis.. As long as it had some forgiving coilover settings with strut braces.
Anywhere over the 300rwhp mark should give the M5 a decent go?
I spose there's always option of a 100 wet shot nos setup :(
I think you should provide a link to your forum so I can check out some 1jz conversions :lol:
Thank you.
here's the link...http://www.zerotohundred.com/newforums/showthread.php?t=2547
and just to inform you, because of government regulations, doing a transplant of engine of different car brand (like toyota engine into Ceffy) is not permitted in Malaysia.
Is the limiter of BMW cars really set to 250kmph? no wonder when I was chasing that M5, it only tops 250kmph, won't go faster anymore....and just to let u guys know, the road condition is not that good here, even on a highway, doing 300kmph would be suicide...even with a full anti-roll cage, best suspensions and great tires.
in the same car I hit 5800 rpm in top and there was still more
yes definatly doable even if a bit hairy especially on bumpy roads 7500 in the same car would be 300 kph from memory. the killer in that car is the 100-to 200 kph time 5 or 7 seconds ( never timed it as your too busy concentrating. 270-280 is definatly achiveable approx 7000 pm.
the cefiro is pretty areodynamic for its age 400 hp + @ the engine would be needed
meggala
5000rpm in 5th gear (in my car) has me sitting at about 240kmph - 250kmph
but I have had a chance to wind it right out to see what it would get to.
But bearing in mind guys the that going from 290kmph to 300kmph the wind pressure on the front of your car almost doubles.
The Cefi's rock... but I think the M5 produces like 450bhp?? That's a sh*tload of power for a stocker... but as someone has duely pointed out.. most BMW "performance cars" are speed limited... that removed, and they can let their full "autobahn" potential be realised.. in short.... cefi would probably get drilled.... Unless modified to a similar spec.
Edited by QUIKBLADE
Tad over 500hp if you use the right settings. Too many buttons to push, by the time they actually have their car set for 500hp, the cef would have lapped it twice :D
The fastest I have been in My C33 Laurel is 255kmph. This is with 8 Point Cage, Swaybars, Strut Braces, Coilovers, 300hp RB25det etc.
So yes I would say definately achievable, jsut with the right Modifications.
You must respect the M5 though. It standard could beat alot of modified C33's/A31's. I have never raced one but I think once I got past the Lag factor It would be on like Donkey Kong.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
