hi guys...im new to this forum..im wondering how to install my new amplifier in my R32, i dont see a hole ion my firewall to be able to put my cables..and i dont want to drill any..anyone have any suggestions or pictures?..any help would be relaly appreaciated
ps..what size are the factory active speakers? 6X9
Edited by demons_wing
https://www.sau.com.au/forums/topic/106759-r32-amplifier-setup/
Hey mate
if you tried the search button you would of found a few threds that cover what your looking for??
There are a couple on the very first page of this section!!!!
http://www.skylinesaustralia.com/forums/in...opic=105491&hl=
http://www.skylinesaustralia.com/forums/in...howtopic=105512
http://www.skylinesaustralia.com/forums/in...showtopic=71256
http://www.skylinesaustralia.com/forums/in...showtopic=98861
There are plenty of spots that you can get your amp cable through but i would suggest the panel on the right hand side of the car, that way you can run all your RCA cables and control wires down the left and wont get any interference!!!
Good luck with it
Cheers GMB
What you need to do is
1. In the car on the drivers side take of the kick panel (right foot side when sitting in the car) with this off you should be able to see the firewall and in the corner a large rubber grommet.
2. Jack the car up, front driver’s side wheel, take the wheel off. once the wheel is off you need to remove the plastic cover in the wheel arch. don’t take it all off as there are like 500 screws just what is nessacery to pull part of it down. ps. you might want to put some car stands to hold the car up instead of leaving the car on the jack
3. standing at the side of the car where you took the wheel off take the power cable and push it through the guard there should be an opening near brake booster side of the guard (back end of the guard behind the strut tower) just feel around under the guard to find the opening. once you have found the opening, push it through the cable should know be in the wheel arc where you pulled the wheel cover down. put your hand up there and find the cable and then push the cable trough the grommet you should be able to feel it at the back of the guard
4. the cable should now be inside the car
mr 32
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
    • Hi, I need same this wing nismo , Does anyone have one for sale?  if any one have can contact me  00966546888343
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
