does any one know if a 1997 R33 sr2 gts4 with 17's 89,000ks. on the road at 18,990 is a good price?
19k for an N/A is a bit much isn't it? we've got series 2 GTSt's for 19k... granted they're not AWD, but they're a lot faster.
