yes i no a stanza is not a skyline but it comes from the same family so...
anyway a while back a mate of mine bought a dato stanza rally car
stanza body
240k suspension
SSS bluebird engine (L20B engine), 5speed tranny and diff
full roll cage
two four point racing seats
rally tyres
handles extremely well
and was pretty quick
plans are for a bigger carby (sidedraught i believe - needs a custom mounting made up)
running really shit at the moment
(new clutch but thrust bearing mounted funny and stuffed master cylinder)
here are some pics
and yes in the background of the first one is a red 120y coupe (not a bad little car specially now with extrators and a 2 inch zorst - with flamer kit for looks to come and a dukes of hazzard air horn!!!! :rolleyes::):):) )
https://www.sau.com.au/forums/topic/106905-datto-stanza/
yeah well the guy he bought it off had dinged it pretty bad quite a few times
i dont think there is an original shell piece on there - it is made up of 5 diff stanzas!!!
Edited by usherly
https://www.sau.com.au/forums/topic/106905-datto-stanza/#findComment-1979756
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
