I reakon they are great looking cars, can't wait to buy one.
One the wieght shift though, even with very stiff track suspension, you get something like 75/25% under braking, I find it very unlikely that it only shifts from 53/47 to 50/50 under acceleration. Sounds like Nissan trying to pull themselves out of a marketing hole there.
https://www.sau.com.au/forums/topic/10692-350z/page/2/#findComment-187945
i think the reason for its shape is because its non japanese design ... i think its either european or american ... i think i was told it was american design ... u know ... renault owns nissan etc ... anyways i reckon those body kits for it look horn ... i'd give up my gtst for it anyday ... but i'd take a gtr over it :)
https://www.sau.com.au/forums/topic/10692-350z/page/2/#findComment-188274
yeh ive read that the weight distribution shifts to 50:50, but ive also read by most test drives that the car ultimatly understeers at its limit.
but shiet i rkon it looks the shiet with the nismo kit, Phwooooarrrrr
anyways, this car is meant to appeal to a global market, hence the curvy looks and the 'safe' understeer
the ass looks a bit flabby tho, and for TWS, its for DUAL phat exaust pipes!!!
https://www.sau.com.au/forums/topic/10692-350z/page/2/#findComment-188385
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
