Hello everyone..
The time has come for me to move on. Im selling my 1994 R33 GTS-T. Ive finished uni and am upgrading. This R33 was imported ~1998 by the owner before me and he spent quite a bit on keeping the car beautiful and reliable. All receipts are with myself.
The car contains:
FMIC and S/S piping done by Per4manz
Exedy 5 puck button clutch installed by X-Speed
S/S Cypher catch can
3 inch mild steel exhaust incl dump and front pipe with 2 s/s cannons
Turbosmart boost controller (ball bearing and spring type)
Turbosmart plumb back BOV
Pioneer stereo
Laserline alarm integrated into immobiliser
Factory sunroof (2 way)
HKS Turbo timer
NGK iridium plugs
Smoke face boost gauge on A-pillar
New tint
Unmarked interior
Clear Headlights (sedan type)
Chromed grill
Sparkling new paint
Original Skyline mats front and rear
The car still drives like new. Ive serviced regularly using Motul oil and have recently replaced the fuel filter, battery, oil and filter.
Come round and have a look and see just how amazingly detailed this car is smile.gif
If anyone wants to know any questions just PM me of leave a post.
Dynoed at 260 rwhp on D/Dynamics dyno few years back on 10psi.
The car has 140000kms. I believe these to be accurate as the car was imported early on and had no need to be wound back like todays arrivals. Also, the condition of the car backs this up.
Price: $16900
Thanks,
Trav
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
