These are my current specs; very happy with the SAFC, the power & vastly improved fuel economy. Well worth the money, and I suspect that when I add larger injectors and a high-flow turbocharger I should see 200awkw or more @ 15psi:-
Dayz special edition Stagea RS V Four
84000kms, automatic, RB25DET engine, Attessa 4wd
Clarion stereo tape unit with 6-stack cd player
Clarion amp
Clarion subwoofer
Pioneer 260w front door speakers
Eclipse 80w rear door speakers
Black Widow car alarm
New Oxygen sensor
Bosch 040 fuel pump with direct battery feed at 13.8volts
Nismo adjustable fuel pressure regulator
Nissan Z32 Air Flow Meter
3inch JustJap stainless single dump pipe system
3inch Catco high flow catalytic converter
3inch Dayz edition cat-back exhaust system with quiet muffler
K&N pod filter in custom enclosure
Apexi 'hybrid' front mount intercooler with custom pipe kit
Hybrid dual stage Electronic Boost Controller, set to 10 & 12psi
Apexi boost gauge
Apexi SAFC Super Air Fuel Computer
Apexi SITC Super Ignition Timing Computer
160 all wheel KW @ 12psi
Edited by Tangles
yeah i'm happy with mine... it all depends on what you want to do with your car... if you want to put a bigger turbo in get a power FC... if you don't want to then the SAFC will suffice...
i said i wasn't going to upgrade the turbo so i put one in, but now i am going a bigger turbo i have a pfc coming, i would not call the SAFC a waste though...
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
