gday, im lookin at getting one of these soon, i know the '93 came with GTR running gear but was wondering if any earlier ones did or if its only on the '93. cheers
buy this bumper....it is difference to the 60000 nismo 400r bumpers you see everyday
Come on, man! That's the front bar EVERYONE gets for the 33. I liked it the first thousand times I saw it...
Now I think it's the factory front bar for a 33 I've seen it so often.
Correct me if I'm wrong, but isn't the point of a custom front bar to be different to other cars like yours, to stand out?
I recommend the Do-Luck front bar. I've tried to attach a picture of the Do-Luck front bar to this reply.
Another good one is Version Select, a link for pic can be found here:
http://www.raceonusa.com/index.asp?PageAct...ROD&ProdID=2553
Or, why not be COMPLETELY different, and get a custom made front bar? Then you are guaranteed no-one has the same one! I can design a few if you want. I'm not sure who does custom front bars in Sydney, but it shouldn't be much more than $400 in any event.
That's my 2c worth anyway.
overly done.......too much neon crap...too much flare on the bumper..........doesn't look tough at all, looks like a 16 year old's car...........no taste........no offense to the owner
lol buy ANY BUMPER as long as it is not 400r
Which bar are you refering to?
its gay look rice boi your not a rice boi are you??
Man, if you got nothing nice to say, just shut the f*ck up!
Here's a couple of nice front bars for 33 I found on yahoo auctions japan:
http://page11.auctions.yahoo.co.jp/jp/auction/n28018313
http://page13.auctions.yahoo.co.jp/jp/auction/r21375004
Have a look!
Have a look!
not too bad at all......could do better with a new grill for the series 2 tho
Yeah, I think the 400R and Trust look is WAY overdone in this country!
The front bars I found are at least something different. Personally, if I wanted a front bar, I would design something completely different to everyone else. Be a trend setter, pussy go getter!!! :D
400r front bar is great looking front bar but the problem is everyone has them so i am anger when i see 60000 each day. i prefere stock bumper to 400r because of this reason.
Who cares what anyone else thinks, if you like it, buy it. It's your car.
At the least it will look different to the hundreds of other 33's I see driving around on any given day
my 2c
totally agree with this. its ur car so who gives a stuff what other ppl think of it. im happy with my 32 gtr being stock lookin even thou lotsa ppl tell me i should get bigger front bar rear bar skirts wide body blah blah. i like the original kit.
u like the bar, buy it!
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
