i recently started a topic in the forced induction section regarding gtr's on p's. i was told that you arent allowed to mod the engine to fall under the 125kw mark its whatever it comes stock. INASNT is what you say here true? are you allowed to do this..or are you just talking about gts-t's..
I heard all the P platers with turbos and pulling them out and installing superchargers to get around the ban :P
p.s. all the topicsi looked for this on are closed and i cant reply so i had to start a new one
https://www.sau.com.au/forums/topic/108078-gtr-on-ps/
INASNT's quote is a joke. (Notice the smiley)
You can't drive a GTR on your P's regardless of if you mod it to make less power (I don't know why you would do that.)
Just get a GTS-4. 4wd + turbo + legal on P's in some state's (Vic)
It's just like a really slow GTR :P .
Hope this helps.
https://www.sau.com.au/forums/topic/108078-gtr-on-ps/#findComment-1993754
As you were told in the other thread dude... in the very first post... which totally dis-counts the "supercharger" comment
I believe the ban is based on a stock standard car, as such you cant drive it legally even if you reduce the power. Its still a GTR, it still originally makes too much power, its still on the banned list.
and
and the simple answer is no
legally you cannot.
And even this about other cars
34 gtt and 33 gtst are over power to weight rule
And hence im locking this thread.
The other threads are also locked... as you can see, the question comes up every 2-3 weeks.
cheers
https://www.sau.com.au/forums/topic/108078-gtr-on-ps/#findComment-1994020
Guest
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
