well... i only have the timing light suitable for a lead ignition set-up.. BUT.. i do have a much much easier way to check. I recently found out that my workshop has a scan tool with DOES imports! SUCH a suprise to me, so I hooked my baby up, found that the base timing is on 5 degrees BTDC.. yuck.. :O
It also has a sweet setup where you can FIX and GRAPH every damn thing the computer is seeing. I now know why my car is running dog rich.. my oxy sensor was showing, yep, you guessed it 0 volts.
This thing is awesome, im so stoked (FYI its a Carman Scan pro, and yes im an apprentice mechanic at a fully equipped work shop:))
To adjust timing you have to loosen CAS then move it which ever way.. is that correct?
https://www.sau.com.au/forums/topic/108335-checking-timing/#findComment-1998272
The scan tool will only show what timing value the ECU is using from it's ignition v load map. You will still need to use a timing light to set the ignition timing using the CAS so that the ECU is getting the right timing value from the CAS.
I find the best way to use the timing light, is to remove the coil from spark plug #1, use a short HT lead between the plug and the coil, and clamp the pickup around this. You can use the small loop of wire near the back of the engine on the ignition wiring loom, but I find that you pick up too much interference using this.
Anti-Clockwise rotation of the CAS advances ignition timing, clockwise retards ignition timing.
Edited by PlasticStan
https://www.sau.com.au/forums/topic/108335-checking-timing/#findComment-1999008
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
