Hey guys i have the above rims available for a quick sale.
There 18s impul very popular rims in chrome they retail for about $2000
But these have a little gutter rash on two rims but can easily be cleaned up therefore im selling them cheaper.
I will take any offer above $1200 will post at buyers expense.
These fit skylines, s14/15 etc
http://www.tempetyres.com.au/products_clos...rt=&part_no=283
My camera isnt workin so the link is to the tempe tyres website where these rims are available i will try to get piks up of the gutter rash soon but if in sydney feel free to come see them. Tryin to get rid of the, before Friday.
Thanx guys any more questions jst Pm me
NEW ALPINE PRODUCTS
Type S 6x9 150ono
mrd-1005 amp 950ono
These are in absolutly great condition
Edited by bdazzld
https://www.sau.com.au/forums/topic/108589-1885-starcorp-racing-impul-chrome/
Ooooo...so tempting.....good price.........so pretty with skylines, yet so common, but still so pretty and so pretty.....................oh well....free bump
i really havent got pics of the rims but there exactly like the pic shows,
I also just double checked the width and they are 8.5" fronts and 9.5" rears so dnt no how the fit on R32 but im sure someone here will know!
As for postage i sent 17" rims to Vic for 100bux jst the other day so it shouldnt be much more than that
to see what these look like have a look on the third page of the photography pics of my car forum
my car is in there its silver 32 gts-t with these wheels
(not these actual wheels but same type)
  • 4 weeks later...
hey guys these are still for sale
stil on the car therefore some tread has been lost 3 tyres have little amounts of tread and would preferbly need replacing but i have already replaced one of the rears
therefore now selling for $950 ono
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
