Hi
Are there different versions of the ER34 PowerFC?
I want to buy one, the serial number is ER34 0002-0005 (rather low number).
I am afraid I will be buying an old version that may not be fully featured.
Does anyone know if this is the case?
I would assume that since the R34 GTT is a fairly new model, there would be only 1 version of the pFC going around.
Cheers
https://www.sau.com.au/forums/topic/108635-powerfc-versions/
I am no expert but I have seen a few different model PFC's and I am thinking the first four digits indicate the year of make (of the PFC) ie 2000, 2nd month.. I could be well off the mark but the newer versions I've seen have indicated to me they're probably a year indicator.
The last four seem like the build number of that make.
if you plug in the hand controller then got to -> etc, then the first option (i think ) then it will tell you the version number of the PFC and hand controller.
You may be better off checking the Power FC FAQ section in the tutorials or contacting PaulR33 IF you can't find it there.
Good luck
Phil
Edited by Fry_33
I have a realted question as well as I received my Power FC today.
I ordered a D-Jetro version and am wondering whether theres anything specific that indicates the D-Jetro version on the box or on the unit itself. The box says Nissan GT-R BNR32/BCNR33, so it is compatible with my car, but theres no word 'D-Jetro' anywhere. The only thing that I can see that could mean its a D-Jetro version is the serial number, which is PFC GTR33D xxx-xxxx
^^does the D in the serial mean D-Jetro?
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
