hey guys and girls, i have been a member of sau for a while now but have never posted anything and have just about finished the outside of my ceffy so i thought id introduce myself and my car. by the way im also a member on ns.com (yelofeva).
Me: Cal. (thats about all i guess your interested in) :)
My Car: Dark blue Cefiro
RB20DET
Uras Kit (what else?)
Apec Apache 17's
Tint
D2 Coilovers
K&N pod
Crankcase airfilter
A few braided hoses :P
Aftermarket steering wheel
Boost and oil temp gauges
Sparco Pheonix seat (got no rails so i havnt put it in yet, if anyone knows anywhere that sells rails for it lemme know.)
i think thats about it, now the outside is just about finished its time for the performance mods :D
so here is my car in its stages:
cef.jpg looks like an amphibian with no bottom jaw! :P
Picture026.jpg sorry bout the small pic, dunno how to resize it.
https://www.sau.com.au/forums/topic/108779-hey-all/
Ooohhh very nice Cal. Welcome aboard SAU!
Another URAS kit....goddamn if only WSX kits could be got....
Glad u got some new rims...the old ones with the kit make it look very....um...funny :D
Is this a daily driver or purpose built for track / drift?
Ando
https://www.sau.com.au/forums/topic/108779-hey-all/#findComment-2004806
yeh cheers guys, thanks for the warm welcome.
nah its my daily driver, was gonna be my drift car but you know how it is, when it gets too precious (expensive) you start to look after it.............
some of you. ;)
Look after your Cefiro..... sorry me no understand... ;)
Very true thou.....some are after a straight daily driver ...PFFT
Some are after a Drift pig... WOOT :)
Each to their own..... but there is no excuse for not sliding a neat Ceffie :)
Ando
https://www.sau.com.au/forums/topic/108779-hey-all/#findComment-2007577
R33Deviat... sure there is :dry: Mine is "Dad will whoop my ass if I make his car a drift pig". He's already givin me grief for bad fuel efficiency coz I put a boost controller in the cef. My old man washes the car every week and vaccumn it, dusts the carpets, even checks the water level in the battery every month. When spares have to be put in he insists on getting OEM nissan parts "because they are guranteed to work properly", even when I can get him spare parts out of japan cheaper. The man is obsessed.
One of these days I'm gonna take the car away, drop it a couple of inches, put some 18's on it and fit a URAS kit onto it. Pimp my ride style :P
https://www.sau.com.au/forums/topic/108779-hey-all/#findComment-2009717
sunroofs don't cost that much you'd be surprised they generally are about $300... or there abouts, you can get fully electric retractables for about $700...
i've got a spare ceffy sunroof sitting in my shed... the glass is cracked but its the whole assembly inc motor etc....
incase anyone is interested :S
https://www.sau.com.au/forums/topic/108779-hey-all/#findComment-2011164
One of these days I'm gonna take the car away, drop it a couple of inches, put some 18's on it and fit a URAS kit onto it. Pimp my ride style :D
Just make sure it's stays auto, set it off with some giovanni 20's on cos you gotsta have da chrome pack. Then he's been officially pimped.
f*kN DIE PIMP MY RIDE :/
https://www.sau.com.au/forums/topic/108779-hey-all/#findComment-2011530
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
