hey guys and girls, i have been a member of sau for a while now but have never posted anything and have just about finished the outside of my ceffy so i thought id introduce myself and my car. by the way im also a member on ns.com (yelofeva).
Me: Cal. (thats about all i guess your interested in) :)
My Car: Dark blue Cefiro
RB20DET
Uras Kit (what else?)
Apec Apache 17's
Tint
D2 Coilovers
K&N pod
Crankcase airfilter
A few braided hoses :P
Aftermarket steering wheel
Boost and oil temp gauges
Sparco Pheonix seat (got no rails so i havnt put it in yet, if anyone knows anywhere that sells rails for it lemme know.)
i think thats about it, now the outside is just about finished its time for the performance mods :D
so here is my car in its stages:
cef.jpg looks like an amphibian with no bottom jaw! :P
Picture026.jpg sorry bout the small pic, dunno how to resize it.
https://www.sau.com.au/forums/topic/108779-hey-all/
Ooohhh very nice Cal. Welcome aboard SAU!
Another URAS kit....goddamn if only WSX kits could be got....
Glad u got some new rims...the old ones with the kit make it look very....um...funny :D
Is this a daily driver or purpose built for track / drift?
Ando
https://www.sau.com.au/forums/topic/108779-hey-all/#findComment-2004806
yeh cheers guys, thanks for the warm welcome.
nah its my daily driver, was gonna be my drift car but you know how it is, when it gets too precious (expensive) you start to look after it.............
some of you. ;)
Look after your Cefiro..... sorry me no understand... ;)
Very true thou.....some are after a straight daily driver ...PFFT
Some are after a Drift pig... WOOT :)
Each to their own..... but there is no excuse for not sliding a neat Ceffie :)
Ando
https://www.sau.com.au/forums/topic/108779-hey-all/#findComment-2007577
R33Deviat... sure there is :dry: Mine is "Dad will whoop my ass if I make his car a drift pig". He's already givin me grief for bad fuel efficiency coz I put a boost controller in the cef. My old man washes the car every week and vaccumn it, dusts the carpets, even checks the water level in the battery every month. When spares have to be put in he insists on getting OEM nissan parts "because they are guranteed to work properly", even when I can get him spare parts out of japan cheaper. The man is obsessed.
One of these days I'm gonna take the car away, drop it a couple of inches, put some 18's on it and fit a URAS kit onto it. Pimp my ride style :P
https://www.sau.com.au/forums/topic/108779-hey-all/#findComment-2009717
sunroofs don't cost that much you'd be surprised they generally are about $300... or there abouts, you can get fully electric retractables for about $700...
i've got a spare ceffy sunroof sitting in my shed... the glass is cracked but its the whole assembly inc motor etc....
incase anyone is interested :S
https://www.sau.com.au/forums/topic/108779-hey-all/#findComment-2011164
One of these days I'm gonna take the car away, drop it a couple of inches, put some 18's on it and fit a URAS kit onto it. Pimp my ride style :D
Just make sure it's stays auto, set it off with some giovanni 20's on cos you gotsta have da chrome pack. Then he's been officially pimped.
f*kN DIE PIMP MY RIDE :/
https://www.sau.com.au/forums/topic/108779-hey-all/#findComment-2011530
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
