okai so i jsut relised wen i turn the car on. on the dash is says "SLIP" and "TRC OFF"
wat does slip mean....
i no wat the TRC OFF means...but the thing is...i got a button under the wheel to turn it on...but wen i press it it still says OFF....isnt it suppose to be on at all times unless i press the button which means it goes off?
https://www.sau.com.au/forums/topic/108799-r34-problems/
You've got a problem and more than likely a big one. Chances are it's your coilpacks but best bet is to take it to a nissan dealer so they can plug in and see what the problem is.
R34's have switchable traction control its on the lefthand side next to the steering wheel. When the TCS is on the "SLIP" light will come on when it senses wheelspin. When the TCS light is on and it displays "TCS off" the slip light will not light up at all, but the car will do burnouts and whatnot.
I don't beleive any of the R33's have traction control, maybe the one's with an A-LSD do but i'm not sure, all other ones do not have traction control at all.
Edited by kralster
https://www.sau.com.au/forums/topic/108799-r34-problems/#findComment-2004534
TCS & Slip light normally means there is a problem with the plug that attaches to the secondary throttle butterfly under the bonnet, unplug it and plug it back on see if the lights go back to normal.
Run a diagnostic check to see what error code comes up
https://www.sau.com.au/forums/topic/108799-r34-problems/#findComment-2004746
can i take it to any nissan dealer?
i swear i just got the car...and im already havn probs lol
If u just got the car, bring it to a mechanic or nissan who have the scan tool and get it checked out quick smart. If the car was from a dealer it should be covered by warranty.
https://www.sau.com.au/forums/topic/108799-r34-problems/#findComment-2005103
This is a common problem with the R34s - a lot of owners have come across this at one stage.
For me it was as simple as making sure the wires were connected correctly and firmly at the ECU. This was after the SAFC2 install where we hadn't tucked all the wires back neatly - it could be a range of other things too but that was my case.
Since fixing the wire arrangement, I've never had that problem again.
https://www.sau.com.au/forums/topic/108799-r34-problems/#findComment-2005784
Nope none of the R33 range comes with traction control, not even the ones with the A-LSD, my mate has one and his doesn't have it
https://www.sau.com.au/forums/topic/108799-r34-problems/#findComment-2007615
I am mistaken ><...nyways the secodary trottle, is that how a TCS works? the secondary valve automatically cuts off the air when the car senses slip?
so if I replace the TB to say Q45, will the TCS still works?
Edited by SKY 34
https://www.sau.com.au/forums/topic/108799-r34-problems/#findComment-2013627
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
